20 Most Recent Magimix 5100 Cuisine Systeme Food Processor Questions & Answers
Contact Magimix directly to request the wiring diagram.
Magimix 5100... | Answered on Aug 25, 2019
You need to replace the spindle i'm afraid which gets worn after a time. There a UK company that sells replacements and tells you how to replace it. Not a big job though a bit tricky. magimixspares.com
Magimix 5100... | Answered on Jul 18, 2017
Yes you can, you can "cut" it off with a soldering iron by melting a slot down one side. When banging a new one on you need to remove the base and suppert the bottom of the shaft with something solid underneath it. The whole motor assembly will be sitting on this as you bang the new sleeve on with a soft mallet. If you don't there is a danger you will wreck the motor and you cannot afford to replace that bit.
Magimix 5100... | Answered on Sep 07, 2014
How to Change a Magimix Food processor plastic spindle.
This is meant as a guide only BBS ltd takes no responsibility for any damage done. We always advise that this should be done by a Magimix approved service agent.
The spindle is the part that sticks out of the motor this drives the blades, knifes, discs and cones for the food processor, this part may become worn after time or use.
Cover the main body with a cloth so as not to damage the look of the food processing machine.
Place two blocks of wood about 10cms either side of spindle cover. Then place two flat screwdrivers Horizontal either side of Magimix food processor spindle
Push down on handle of screwdrivers apply even pressure (keeping eyes well away from the spindle cover, they can fly off fast sometimes.)
The spindle will rise.
This will leave the metal centre shaft, Replace with a spindle cover bought from
www.magimix-spares.co.uk. Make sure you choose correct model, usually named on front of machine, or phone 01252 727755 for help.
When replacing, make sure that the New Food processor spindle is lined up and slide the spindle onto the centre shaft. Make sure this goes all the way down by gently tapping with a hammer.
All blades and attachments should be checked before placing back onto spindle cover, if the inside is damaged, this could damage the spindle cover again, any blade, dough blade , disc support that is marked should be replaced.
BBS Limited is the approved and dedicated supplier of Magimix parts & accessories for all Magimix products.
Please telephone +44 (0) 1252 727755 or fax +44 (0) 1252 727766 for help or advice. All images and text are Copyright (c) 2008 BBS Limited.
Magimix 5100... | Answered on Nov 11, 2013
The shaft sleeve (the one on the motor shaft) is likely damaged. The correct solution is a new shaft sleeve and chopping blade. If you do not replace them both together the one you do not replace will damage the other one again.
Magimix 5100... | Answered on Oct 18, 2013
New shaft cover req about £10.00 you will proberly have to replace any damaged blades aswell.
Magimix 5100... | Answered on Aug 23, 2013
Magimix 5100 Cuisine Systeme Food Processor Logo
69 questions posted
Top Magimix Food Processors Experts
Ross Keen
Andrew Taylor
Andrew Taylor
Ruth summersides
Are you a Magimix Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Magimix Food Processors
Most Popular Question
magimix sytem cuisine
  • Food Processors
