20 Most Recent Acer Aspire 5100 Notebook Questions & Answers
You cannot copy Audio from Youtube. But there is an alternative. First you need to install Youtube Downloader in order to download the videos or the audios from Youtube.
Next you will also need a FLV to MP3 converter in order to get the Audio which will be compatible for CD or iPod as files downloaded from Youtube will come in .flv extension which doesn't work on normal CD player or iPod.
Acer Aspire 5100... | Answered on Apr 17, 2019
You are missing the file NTLDR.exe and NTKRNL.exe. NTLDR is the first file your computer sees when it is booting up and it brings up other files to get your computer started then it turns it over to Windows file called NTKTRNL which actually brings up the Windows operating system. The only wayto fix is to find a Windows disc and copy them over to three folders that you have either win32, windows or winnt. Copy to all three if you see all three buy only one of those starts your system and it seems like it's win32 based on your error, folder under your C: drive. That will solve your problem and your computer will boot up normally.
Acer Aspire 5100... | Answered on Mar 09, 2019
You will need to send the laptop to acer for repair service. they will re-flash the bios update to get the laptop working again.
you simply don't have the tools required to do it at home.
Acer Aspire 5100... | Answered on Dec 13, 2018
what is it?a support driver?you can download it in acer website by using correct searce engine and by inputing the correct model.
Ok I am not sure what does your phone have to do with the computer profile? it seems that at one point you were connected to a network and now it does not find the domain; your account seems to be Not associated with it anymore and can not find the account you are logging in at the moment therefore creating a temporary account, seek the help of a network professional or a system admin so that he can help you solve the issue.
Acer Aspire 5100... | Answered on Feb 05, 2018
The DVD ROM problem lies in the REGISTRY. I have the registry entries. I can email it to you. I have the same lappy running 7. It aint supported but that mean it don't work! :)
Acer Aspire 5100... | Answered on Jan 29, 2018
sorry we are not password experts . we can not read minds you see
Acer Aspire 5100... | Answered on Aug 22, 2017
I have an Acer 5420 which had a persistent disconnection problem after startup, with either the wireless or LAN connection. It appears that the Microsoft network application would startup and make the connection, but seconds later the Acer Enet Management application would start, and its first act would be to disconnect from the Internet. Since the Microsoft network application provides every feature that I want, I choose to disable the Acer Enet Management.
  1. Following up on a hint from on of the posts, I went to Start -> Programs -> Accessories -> Command Prompt.
  2. At the command prompt window, I typed msconfig
  3. About a minute later (after Vista confirmed that it was OK to run this program, the System Configuration window comes up, where I selected the "services" tab
  4. Scrolling down the numerous services, I found "eNet service" and clicked the check mark to disable the service. Hit apply and OK, and restarted my laptop.
  5. The problem went away after that.
Acer Aspire 5100... | Answered on Jul 01, 2017
I agree. Re imaging or reinstalling the windows operating system seems like the only fix at this point since it seems like the anti virus isn't picking up the virus. Back up the files on an external hard drive and just reinstall windows.
Acer Aspire 5100... | Answered on Jun 22, 2017
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Acer Aspire 5100... | Answered on Jan 13, 2017
This answer is pretty late but all u need is an HDMI cable to make the connection. You can also use a projector cable to make the same connection but plugged in a diferrent port at the back or your TV. If your computer doesn't have an HDMI port u can still use the VGA(projector cable) to make the connection
Acer Aspire 5100... | Answered on Nov 22, 2016
  1. Most Programs Don't run 64 bit operating systems very well nor have the driver support 32 bit will work fine setting that aside open internet explorer left click tools go to compatibility view settings check display all websites in compatibility view. And read below as well if this is no fix go to skype support for more help.This sounds like your problem is yours in settings .
  2. Update your Windows with the latest Service Packs and updates, available via Windows Update.
  3. Then reinstall Skype.
  4. After installing Skype it's important to adjust your firewall settings.
  5. Ensure you have the latest device drivers for sound and video (available on the device manufacturer's website).
  6. Make sure that you have the latest version of DirectX (the core multimedia component of Windows) installed on your computer.
How can I see how much bandwidth a Skype video call is using? To see how much bandwidth is being used during a video call for:
Skype for Windows
  1. Go to: Tools > Options > Advanced > Advanced settings
  2. Tick option Display technical info during calls
  3. Click Save
During calls, click on the downward-pointing arrow (next to the volume slider) - it has the rollover text Other call functions - and choose Call Technical Info.
Bandwidth (BW) usage is shown under the Basic section:
BW (avg/60sec): upload
BW (avg/60sec): download
Acer Aspire 5100... | Answered on Oct 12, 2016
These are the text-only instructions:
Launching the Acer OrbiCam
To launch the Acer OrbiCam, double-click on the Acer OrbiCam logo in the
desktop.
OR
Click Start > All Programs > Acer > Acer OrbiCam. The Acer OrbiCam capture
window appears.
Changing the Acer OrbiCam settings
Resolution
To change the capture resolution, click the displayed resolution at the bottom
right corner of the capture window, then select the desired resolution.
Note: Setting the camera resolution to 640 x 480 or larger does
not change the capture window size.
33
English
Options
Click Options to display the Window, Preview, and Folder tabs. Use the options
to change the capture window size, preview settings, and the folder for
captured photos or videos.
Camera Settings
Basic settings
Click the Camera Settings icon on the bottom right corner of the capture
display, then select Camera Settings from the pop-up menu. You can adjust the
Video, Audio, and Zoom/Face tracking options from this window.
34
English
Capture settings
From the Camera Settings window, click the Driver Settings button. The
Properties window appears.
Device Settings allows you to change the camera brightness, contrast, hue,
saturation, sharpness, etc.
Advanced Settings allows you to activate gain control, implement image mirror,
select image enhancements and anti-flicker settings, and turn on/off the camera
indicator.
Zoom/Face Track Settings allows you to adjust the zoom level and turn the
face-tracking feature on or off.
Capturing photos/videos
To capture a photo or a video clip, rotate the Acer OrbiCam to get the desired
angle, then click the Take a Picture or Record a Video button. The Windows
Picture and Fax Viewer or the Windows Media Player automatically launches to
display/play a preview of the photo/video clip.
Note: By default, all photos and videos are saved in the My
Pictures and My Videos folder.
Using the Acer OrbiCam as webcam
The Acer OrbiCam is automatically selected as the capture device of any Instant
Messenger (IM) application. To use the Acer OrbiCam as a webcam, open the IM
service, then select the video/webcam feature. You can now broadcast from
your location to an IM partner anywhere in the world.
Acer Aspire 5100... | Answered on Oct 07, 2016
REMOVE AND 20 MIN AFTER REFIX CMOS BATTERY. GO TO CMOS SETUP RESET DATE AND TIME...... IF NOT CLEAR VISIT YOU NEAREST MYTECH SOLUTIONS LAPTOP SERVICE CENTRE. WWW.MYTECHMADURAI.COM
Acer Aspire 5100... | Answered on Aug 13, 2016
Acer Aspire 5100 Notebook Logo
2,905 questions posted
Ekse
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
download acer arcade or acer arcade
  • Computers & Internet
