20 Most Recent Apple iPhone Smartphone Questions & Answers
Usually this type of problem is battery related.
take it to apple shop it should still be under the 2 year mandotory warranty.
Apple iPhone... | Answered on Feb 12, 2019
Contact your telco via phone. They need to set up the service and then you will see notifications via text. Usually it is a value added service, mine is $10 for voicemail, who called and number display.
Apple iPhone... | Answered on Feb 07, 2019
What sim card do you have in your iPhone. If you updated your iPhone to the new 2.0 software then unlocking the iPhone will be impossible.
Thank you, Apple Care Technical Support Nick M.
Apple iPhone... | Answered on Feb 05, 2019
Setting Outgoing Server on iPhone
1. From the Home screen, tap Settings.
2. On the Settings screen, tap Mail, Contacts, Calendars.
3. On the Mail screen, under Accounts, tap your Roadrunner account.
4. Tap Outgoing Mail Server (SMTP).
5. Tap Primary Server (might say, smtp-server.roadrunner.com or some other rr server)
Host Name
Change Host Name to cwmx.com
User Name
Leave blank
Password
Leave blank
SSL
Make sure SSL is off
Authentication
Should say Password
Server Port
Should say 25, if not change to 25
As an alternate if the above does not work: After tapping Outgoing Mail Server (SMTP), look for AT&T SMTP Server, tap it, then turn Server to ON
Good Luck!
Apple iPhone... | Answered on Feb 01, 2019
If your iPhone can be recognized by iTunes, the recovery will be much easier for you. Besides iTunes, if you only want to recover photos from broken iPhone only and save them on computer, there are also several methods available for you. Download Leawo iOS Data Recovery ' Leawo iOS Data Recovery for Mac and install it.
Step 1: Choose Recover from iOS Device
Run Leawo iOS Data Recovery and choose Recover from iOS Device.
Step 2: Click Start Button
Connect iPhone to computer with USB cable. Then click the Start button.
Step 3: Select iPhone Photos
The program scans your iPhone. Check Camera Roll when the scan finishes, and select the photos you need. Then click Recover.
Step 4: Choose Target
Click Open in the pop-up dialog to choose a target folder on your computer. Then click Go to start recovering photos from broken iPhone.
recover-from-ios-contacts-hraoc4bd1cy3f24n2aesny2m-3-0_0.jpg For more detail, check: How to Recover Photos from Broken iPhone
If your iPhone has been disabled, it is completely locked down. The only way you'll be able to use it again is by restoring it using iTunes or iCloud. If you have a backup, you'll be able to recover your data, but this process will delete everything that is stored on the iPhone. Except for the following four ways, there is no other way to unlock a disabled iPhone. Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
For more detail, check: How to Unlock A Disabled iPhone with/without iTunes
restore your iphone to factory settings this will solve your problem go and get this click here it will jailbreak your iphone and unlock it to any sim this gu will help you just tell him your problem and he will solve it he's a god with all things iphone.
Apple iPhone... | Answered on Jan 31, 2019
You need to install itunes on your laptop so your iphone can sync with itunes and your computer.. this is used to tranfer music to your iphone, transfer photo's and video etc and also to check for new firmware versions/back up your phone.
You can however take photo's from your iphone without itunes if you connect your phone via usb and choose open folder to view files when the dialog pops up after you plug it in.. this has very limited use however you really need to install itunes. Itunes is a free download
Apple iPhone... | Answered on Jan 29, 2019
Go to settings in your Facebook menu and turn off your "status" off, it's a common issue.
if this helped any please let me know and have anawesone day!
Apple iPhone... | Answered on Jan 28, 2019
Best thing about this new service is that you are HELP NUMBER +1 833 272 0777never placed on hold and get to talk to real repairmen in the US.
Apple iPhone... | Answered on Jan 23, 2019
To recover deleted/lost data from iPhone/iPad/iPod, you can use iOS Data Recovery to recover data from iOS Device, iTunes Backup file and iCloud backup file.
How to Recover Lost iPhone Data with iPhone Data Recovery
  1. Open the Settings app and go to "General" and then to "Accessibility"
  2. Toggle the switch for "Grayscale" to the OFF position
  3. That change will be instant, with grayscale off the iPhone will exit out of black and white mode and you'll be back to a color display.
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Apple iPhone... | Answered on Jan 07, 2019
Contact apple or your service provider
The screen is replaceable. That being said, replacing a cell phone screen is similar to working on a watch. VERY tight, very compact, very prone to damage if you're not careful.
That being said, if you want to try it yourself, I'd recommend checking out http://www.ifixit.com. This site provides the tools, parts and repair videos to explain how to fix the device.
If you're not comfortable working on a very compact device, then you should be able to find many local places that provide that service for you.
Apple iPhone... | Answered on Jan 03, 2019
UNLOCK IPHONE ANY MODEL AT HOME
----- NEW Unlock iCloud -----
PHONEUNLOCK.ORG
www.phoneunlock.org
Unlock iCloud, iCloud Removal Service
Unlock iPhone All Models
- iCloud Activation Lock
- iCloud Passcode
- Fingerprint
- iPhone 8 Face ID
- Find my iPhone
- iCloud Owner Message
- iCloud Lost mode with Owner Message
- Blacklisted
- iCloud Blocked Device
- Factory Lost
- Untrusted Device
- Unlock iPhone ALL Models Network Mode
- Unlock iPhone SIM Lock
Available for iPhone X, 8 Plus, 8, 7 Plus, 7, SE, 6S Plus. 6S, 6 Plus, 6, 5S, 5C, 5, 4S, 4 on all iOS and iPad Versions.
Tested and reviewed by https://unlock-icloud.com
Get and Download Now iCloudRemover Unlock Tool
Start unlock at Home or Office http://phoneunlock.org
iCloudRemover Unlock Carrier List (GSM, CDMA carrier unlock mode IMEI unlock changer)
Unlock iCloud iPhone Airfire Mobile
Unlock iCloud iPhone ASTAC
Unlock iCloud iPhone Asset/Vada Wireless
Unlock iCloud iPhone AT&T (all)
Unlock iCloud iPhone Broadpoint
Unlock iCloud iPhone Big Sky Mobile
Unlock iCloud iPhone Calhan Wireless
Unlock iCloud iPhone call4care
Unlock iCloud iPhone Cellular One of East Central Illinois
Unlock iCloud iPhone Cellular One of East Arizona
Unlock iCloud iPhone Cellular One Nation
Unlock iCloud iPhone Cellular One TXOK
Unlock iCloud iPhone Chariton Valley Wireless
Unlock iCloud iPhone Cincinnati Bell Wireless
Unlock iCloud iPhone Commnet Wireless (also uses CDMA in some areas)
Unlock iCloud iPhone Consumer Cellular
Unlock iCloud iPhone Cordova Wireless
Unlock iCloud iPhone Corr Wireless
Unlock iCloud iPhone Cross Communications
Unlock iCloud iPhone vDTC Wireless
Unlock iCloud iPhone Earthtones
Unlock iCloud iPhone Epic PCS
Unlock iCloud iPhone FreedomPop
Unlock iCloud iPhone Fuzion Mobile
Unlock iCloud iPhone GCI Wireless (also uses CDMA in some areas)
Unlock iCloud iPhone GTC Wireless
Unlock iCloud iPhone GoSmart Mobile
Unlock iCloud iPhone i wireless
Unlock iCloud iPhone Immix
Unlock iPhone Indigo Wireless
Unlock iCloud iPhone Jolt Wireless
Unlock iCloud iPhone KTC PACE
Unlock iCloud iPhone Long Lines Wireless
Unlock iCloud iPhone Mobal Freedom
Unlock iCloud iPhone Metro PCS (also uses CDMA in some areas)
Unlock iCloud iPhone NEP Wireless
Unlock iCloud iPhone Pine Cellular
Unlock iCloud iPhone Plateau Wireless
Unlock iCloud iPhone Pure Prepaid
Unlock iCloud iPhone Pure Talk USA
Unlock iCloud iPhone Simple Mobile
Unlock iCloud iPhone Telecom North America Mobile Inc
Unlock iCloud iPhone TerreStar
Unlock iCloud iPhone T-Mobile USA
Unlock iCloud iPhone TracFone Wireless (also uses CDMA in some areas) (Includes NET10 Wireless, SafeLink Wireless, Straight Unlock iPhone Talk, SIMPLE Mobile and Telcel Am?rica)
Unlock iCloud iPhone Tru
Unlock iCloud iPhone Union Wireless
Unlock iCloud iPhone Viaero Wireless
Unlock iCloud iPhone Wal-Mart Family Mobile
Unlock iCloud iPhone West Central Wireless
Unlock iCloud iPhone Westlink
Unlock iCloud iPhone XIT Communications
Unlock iCloud iPhone Vodafone
Unlock iCloud iPhone Orange
Unlock iCloud iPhone Telekom
Unlock iCloud iPhone Tim
Unlock iCloud iPhone O2
Unlock iCloud iPhone Al
icloud Unlock iPhone All Models
2 Minute Unlock iCloud
iCloud Unlock Reveal
Unlock iCloud Tutorial
Unlock iCloud Free Video
Unlock iPhone by IMEI changer iCloudRemover 1.0.2
Unlock iPhone All Models iCloud Removal
Unlock iPhone All Models Remove iCloud Lock
iCloud UNlock iCloud Removal unlock iPhone
Unlock iCloud iPhone All Models
Unlock iPhone iCloud Lock Activate iPhone iCloud
Unlock icloud, icloud unlock, UNLOCK ICLOUD, unlock,icloud, icloud lock,remove icloud, icloud unlock,icloud locked, icloud remover, activate iphone, unlock iphone, all, iphone, unlock iphone 7, unlock software, flash software, cell unlock, iphone unlock. Unlock iCloud Service Unlock iPhone iPhone XS iPhone Max Permanently
Apple iPhone... | Answered on Jan 01, 2019
I understand if you go to the portal and request an unlock on your phone then you will be able to switch to ATT.
Apple iPhone... | Answered on Dec 29, 2018
With all this type of app it all depends on who else has the app. This one is very obscure, Google doesn't know 'Big Green App', compared to Facebook Messenger, WhatsApp and Viber.
You have to tell it to scan your Contacts List and it magically finds those people who have the app. You can only text those people using the same app as you have.
If you mean the Green Text App that comes WITH the iPhone that has 'Messages' under it, you can text ANYONE in your Contacts list, or even type new numbers in.
Get another mophie!
Apple iPhone... | Answered on Dec 23, 2018
8,182 questions posted
Popular Products
Top Apple Cell Phones Experts
jacobcheatha
Level 1 Expert
Marvin
Marvin
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
sync iphone outlook
  • Cell Phones
