20 Most Recent Toshiba Satellite A135-S2276 Notebook Questions & Answers
sir my all softwares r installed properly & im using vista stater. my web cam is not able 2 b detected
Toshiba... | Answered on Nov 26, 2018
13 year old PC,
if you lost the BIOS admin password, that can be hard to reset but 13 year old PC are the most easy
every year it gets harder.
did you google this first.
the maker of the PC has no real form at all.
so that is why you are here, because you can't ask the maker, but in all cases of all makers of PCs all there forums are not allowed to discuss this topic (hacking passwords)
as of march 2018 this topic is illegall(sic)
but we at fixya can tell you that you can google and read, or go to youtube, and see if someone has hack for this, did you?
the OEM page is this only
https://support.toshiba.com/support/navShell?cf=tais_kb
the hacking is here. I do not promote hacking but there is no other choices but and OEM fix or hacking or new MOBO.
1 second search here shows. (youtube has many)
https://www.youtube.com/watch?v=SxGviSv7EoA
then video is not very good, but shows locates at end clearly see the J1, jack it seen 2 squiggly line trances there of copper, jump the squiggly.4153bb5a-8149-42b0-81c6-0baa48a1a81a.jpg
Toshiba... | Answered on Nov 10, 2018
F2 key method Turn the computer on. If you see an invitation to press the F2 key to enter Setup, do so. The Setup screen will appear.
Toshiba Hardware utility method Run the Toshiba Hardware utility from the Toshiba Console. It may also accessible (as 'HWSetup') from the Windows Control Panel. Changes to some of the settings will require re-starting the computer. This method is the only way to access the BIOS settings on some notebook PCs (Satellite 5000 series, for example). (For these machines, pressing and holding the F12 key immediately after powering-on the notebook will allow you to alter the notebook's boot priority.)
If the Toshiba Hardware utility is not present, try the F2 key method and the Esc key method (see below). The Toshiba Hardware utility may be downloaded from the Toshiba support website at //support.toshiba.com
If the computer is fully off, and/or to avoid having to re-start it (and Windows), use one or the other of the following two methods. The PC will have to be truly off (not suspended, or in standby mode, or in hibernation mode). If an external keyboard is attached to the notebook (either directly or via a docking station or a port-replicator), disconnect it until you have completed this procedure.
Esc key method Turn the computer on. If you do not see a prompt to press the F2 key, then immediately press and hold the Esc key for three seconds, and then release it. When prompted to, press the F1 key. The Setup screen will appear.
Toshiba... | Answered on Feb 09, 2018
Toshiba A135-S2276 Win XP Satellite Drivers free downloading
Toshiba... | Answered on Jan 26, 2018
It is possible that your VGA is malfunctioning. But you will notice it when the screen resolution is set to a specific resolution and color depth.
Games play at it's own resolution. Not at the resolution you set for Windows. Probably WoW is setting the screen resolution and color depth to a values at which the VGA fail.
Did you try changing the screen resolution in WoW options? If not try it. Also try changing color depth.
Also, download GPUZ and check your VGA.
Best of luck!
Toshiba... | Answered on Dec 10, 2016
We cannot provide you with a key. If you have purchased the Windows operating system, the key came with it.
To provide you with a key would amount to software piracy which we do not condone.
Toshiba... | Answered on Feb 02, 2016
If the cursor highlight is positioned over the START button (icon) then you can select it by pressing ENTER or SPACE bar, which is the keyboard equivalent of double clicking with the mouse. To move between the fields, press the TAB key (shift TAB to go backwards or to the previously selected field).
However, the question is not clearly stated...
Toshiba... | Answered on Sep 07, 2015
Available RAM is very important for speeding up your laptop while surfing. Check your available RAM by:
  1. Starting the Task Manager (Right click on taskbar and select it)
  2. Select the Performance Tab
  3. Compare the Physical Memory vs Commit Charge numbers.
For example, my fast computer has 3600 megs of total physical memory compared to a commit charge of 1200 megs. Meanwhile, my older, slow computer has only 650 megs of total physical memory with a commit charge of 1400 megs. This means the slow computer is always making 'pretend' memory from hard drive space, and that is why it is so slow. This is most likely the case with your computer as well.
I hope that helps.
Toshiba... | Answered on Sep 06, 2015
have you installed any other software recently? you might try system restore and if that didnt work,try uninstalling and reinstalling your webcam driver
Toshiba... | Answered on Jun 06, 2015
If you've lost your product key, then there's a help, you can ask for a replacement from the Microsoft, but if it's a pirated product, i am afraid that you'll get it easily. As you know, everything is possible nowadays, so there's still possibility. But unfortunately we can't provide you the key here since it's illegal to distribute copyrighted product. If you don't mind please visit this link and ask for help. http://help-and-get-help.gu.ma/ Good luck.
Toshiba... | Answered on Apr 27, 2015
When I turn on the computer...
I get a message " Bootmgr is compressed"
and to press CTR (t) ALT (t)
and when I do, the screen returns to the
top message: Bootmgr is compressed.
If I can, what do I need to do
to get to my desk top?
Toshiba... | Answered on Apr 19, 2015
more info please
Toshiba... | Answered on Apr 13, 2015
http://images.frompo.com/306af19cc0a2a8d80e44c7620e69d28f
goto this link and see if this is what you are looking for.
Toshiba... | Answered on Apr 12, 2015
1)Remove Laptop Battery
2)Take off Memory Cover(underneath - square cover, Sits
in middle of laptop 1 retaining screw
3)Using two thumbs spread spring clips to outside and
pull out RAM memory.
4)Remove clear vinyl label opposite RAM memory slots in
upper left corner( laptop battery slot is on right, DVD
drive is facing away from you)
5)Using a magnifying glass (unless you have perfect
vision)in the upper left corner you will see JOPEN1 with
a white silkscreen square next to it . Inside the square
you will see what looks like the letter T over a U.
Using a metal paper clip short the U to the Silver 1/4"
post connecting the motherboard to the laptop case(this
is you ground, it is located above what looks like a
silkscreen outline of a chip)hold for 25 -30 seconds.
6) Place back your RAM memory, put in the laptop battery
and test start laptop. you should see a selection of F1
or F2 for setup. Using the F2 gets you into the Bios
menu where you reset the time and date. Then Tab over to
the SECURITY setting tab and change your passwords. Now
hit F10 key ,yes to save and your done!
check the video as well
https://www.youtube.com/watch?v=Eo1gg1EZV-o
Toshiba... | Answered on Apr 04, 2015
Bios / Motherboard Request Board [Archive] - Page 5 - DriverGuide ... Toshiba A135 S2276 (Windows Vista) DRIVER ... 760gx-m motherboards drivers (Windows XP ... ga-61eml (Windows XP Professional) DRIVER NEEDED:
Good Luck, Please dont for get to Vote/Thank You.
Toshiba... | Answered on Mar 26, 2015
type this in your search engine ....
toshiba support-content list
some tittles of exactly what you typed in will display...
click on one and youll be at the download page...
just been there.I'd type the page in for u but its very long as youll see when u get there.
some set a password for you laptop.. you need to contact toshiba for this and prove ownership for the laptop.. or... you can try to open up your laptop and short the bios battery so it would reset..
you need to upen up your toshiba, and disconnect the internal battery, not the big one. Or, maybe a simpler method - call toshiba to check if there is a master password from them... :-)
1,118 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
product key windows vista home premium
  • Computers & Internet
