20 Most Recent Amana ARB1917CSR Bottom Freezer Refrigerator Questions & Answers
no the ground is for your safety in case of short circuit. you can use an adaptor its up to you
Amana ARB1917CSR... | Answered on Sep 25, 2017
Contact the repairclinic.com for tech advice, they are very knowledgeable about these types of problems and what causes them, the service is free and they can sell you the needed parts after you chat with them online.
Amana ARB1917CSR... | Answered on Apr 20, 2017
An owners manual I found online says:
Freezer
  1. Pinch rear tabs on light cover and pull straight down.
  2. Remove light bulb.
  3. Replace bulb with appliance bulb no greater than 40 watts.
  4. Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
Amana ARB1917CSR... | Answered on Aug 05, 2014
I picked up on something you wrote within your problem description. "got the thermostat replaced under warranty" & "that worked for a while ". back in Aug of 2002. It's August of 2008 and your thermostat may have failed again. 6 years later... not so unusual. Anyway, since your fridge has a bottom freezer, there must be a pass thru between the freezer and the fridge compartment in an area you haven't examined yet. The fridge gets cold air delivered from the freezer to keep it cold thru this pass thru and many fridges have an adjustable flap that allows you to limit that cold air flow. Time permitting, can you do a more thorough examination of the fridge area ( side walls near crisper drawers perhaps?) or better than that, remove the drawers and look for that air duct pass thru. Once located, if it does not have an adjustable damper, try a little duct tape to limit the amount of cold air from migrating into the fridge compartment. Other options: Can you contact Amana customer support directly and get their support? That particular model has been discontinued by Amana but they should be able to support it. Not sure I added anything to what you already know. Gave it a shot thou...
Amana ARB1917CSR... | Answered on Sep 04, 2013
Yes the door can be changed to open from the opposite side, there are removal plugs that need to be removed from the opposite side and just change all the hardware from one side to the other, change the middle hinge first and put on the bottom door first, after its is mounted you can put the bottom part of the top door on the hinge and last the top hinge, and just make a few minor adjustments.
Amana ARB1917CSR... | Answered on Jan 08, 2012
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Amana ARB1917CSR... | Answered on Aug 14, 2011
sounds like the ptc relay/ overload on the compressors bad
Amana ARB1917CSR... | Answered on Aug 07, 2011
heatman101
Amana ARB1917CSR... | Answered on Jul 17, 2011
Bad circuit board
Amana ARB1917CSR... | Answered on May 01, 2011
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Amana ARB1917CSR... | Answered on Oct 06, 2010
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Amana ARB1917CSR... | Answered on Sep 27, 2010
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Amana ARB1917CSR... | Answered on Sep 11, 2010
Amana ARB1917CSR Bottom Freezer Refrigerator Logo
41 questions posted
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Amana Refrigerators
  • Amana Refrigerators
Most Popular Question
amana arb1917cb bottom freezer
  • Refrigerators
