20 Most Recent Fujitsu Siemens PlasmaVision P42VHA40 Monitor Questions & Answers
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Fujitsu Siemens... | Answered on Feb 03, 2011
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Fujitsu Siemens... | Answered on May 03, 2010
HX2BJ-YJTTY-T27MD-767KP
this code is for all xp versions of windows but will need activating
Fujitsu Siemens... | Answered on Nov 12, 2013
check connections most likely culprit is a blown fuse on the screen mainboard very easy to replace but must be soldered unless you use a little bit of copper wire twisted and rolled up to cover both ends of the internal fuse then stick it down with insulation tape but do this at your own risk
It's the condensator near RAM. Exchange - it works.
300 µF / 6,3 V
Fujitsu Siemens... | Answered on Jan 13, 2019
WPA2 is considered insecure and hacked years ago.
You might try WPA, or get a different Adapter.
Fujitsu Siemens... | Answered on Sep 09, 2018
No need as when you boot from the disc there will be the option for a clean rebuild which formats the drive.
Follow the prompts.
Fujitsu Siemens... | Answered on Dec 04, 2017
Whenever you can't connect to a network it is rarely the computer that is at fault, especially if it has been working.
Step 1, however, is to turn off your modem, router, and computer for 10 to 30 seconds, then turn on the modem and router (often the same unit), then the computer. If the computer is connected to an Ethernet cable, make sure you see lights on both ends of the cable, on the router and on the computer, if not, unplug and re-seat the plugs.
Step 2, If step 1 did not resolve the problem, bring up your command line on the computer. In Windows, click start and type cmd then hit the enter key or Win+R, type cmd and hit the enter key... this will bring up a command line tool. In Linux, find the terminal app.
Step 3, in the command line tool, type: ipconfig (ifconfig if you are using an Apple or Linux product) and hit the enter key.
You will be presented with a list of items, look for your IPV4 IP Address. Your IP address should look something like 192.168.0.048. If the first number is 169 you are not connected to any network. Look for a default gateway and write down that IP address (usually 192.168.0.1, but could be something like 10.10.0.1)
Step 4, type the command ping 192.168.0.1 (use your gateway address). If you get replies back from that, you are able to talk to your router.
Step 5, type the command ping google.com. If you get no replies back, your internet service provider is most likely down, and you should call them. It could also be that your DNS server is not properly configured in your network settings, but if your computer WAS working, it should still be OK.
Step 6, If none of the above solves your problem surfing the web with a browser, then your browser may have been hijacked, you will want to run a couple of good anti-malware utilities to find out. I use two to solve most problems: HitManPro (www.hitman.com) and MalwareBytes (malwarebytes.org)
Fujitsu Siemens... | Answered on Oct 25, 2017
Usually you can hook up a monitor the the VGA out on a laptop and then find the info you need. Hook it up before you boot.
Fujitsu Siemens... | Answered on Oct 02, 2017
See link, all you have to do is enter your serial number.
http://support.ts.fujitsu.com/download/index.asp?lng=com
Fujitsu Siemens... | Answered on Aug 27, 2017
All your data is probably OK. The best way to access it is to remove the disk and put it into another computer. You should then be able to find the data on the disk, although it will have a different drive letter. Next time make sure your keep back-ups of all your important data.
Fujitsu Siemens... | Answered on Aug 20, 2017
Fujitsu Siemens PlasmaVision P42VHA40 Monitor Logo
11 questions posted
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
PlasmaVision Fujitsu Siemens
  • PlasmaVision Fujitsu Siemens
Most Popular Question
our cable box
  • Computers & Internet
