20 Most Recent Toshiba Satellite A60 Notebook Questions & Answers
Here is the fix my toshiba laptop also wouldent turn on so i call them and here is what you do 1. unplug the laptop
2.take out the battery 3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit) 4.put battery back in 5.plug in laptop 6.try to turn it on
hope this helps
John
Toshiba... | Answered on Feb 28, 2018
let it be checked by technician
Toshiba... | Answered on Nov 18, 2017
Just hold windowskey+r, then type charmap then select @ symbol in the pop window. Press copy button then use this wherever you want.
Toshiba... | Answered on Jul 02, 2014
First I would check to make sure your drivers are up to date.
Toshiba... | Answered on Jun 23, 2014
You can use regular windows cd and install drivers from Toshiba webiste. I don't think cds are available now.
Toshiba... | Answered on May 24, 2014
Does it display on an external monitor? Try reseating the Ram chips
Toshiba... | Answered on May 22, 2014
It would have helped to have the complete error message so I wouldn't have to guess, but rtl120.bpl appears to be related to something called "TuneUp Utilities 2010." Further, some anti-virus applications apparently were detecting this file as a Trojan horse (and thus deleting it or quarantining it) although those "false positive" detections were from Dec. 2009 and I would have expected the issue to have been long since dealt with.
Assuming that you have something like TuneUp Utilities 2010 installed, I suggest that you uninstall it. As a general rule, such utilities don't provided much benefit (other than to the income of the vendor) but have the potential for causing problems to your system. If you can't uninstall whatever it is from Control Panel > Add or Remove Programs, you will probably succeed with free Revo Uninstaller.
Toshiba... | Answered on Mar 29, 2014
Run a registry cleaning program.
Toshiba... | Answered on Mar 08, 2014
The error could be connected to the advanced system care. Have you uninstalled any protective software lately?
It would seem that as the computer is starting it is trying to load a program that is either corrupt or missing, generally a program like reg cleaner or other utility program.
If its a case you have removed a program, try installing it and see if that works.
Get another copy of the advanced sys care program and reinstall that.
If this doesn't work, get back to me.
Toshiba... | Answered on Jan 30, 2014
Go to Toshiba.com and download the drivers from there. You will then have the latest drivers.
Toshiba... | Answered on Jan 19, 2014
It sounds like your Computer is not reading the HDD correctly or you may have a corrupt operating system. If you have an install disk try to boot from that. I cant be very specific since your question is very vague and doesn't make a lot of sense.
Toshiba... | Answered on Jan 18, 2014
Download the OS from microsoft and install it. Don't forget to install all of the drivers!
Toshiba... | Answered on Dec 30, 2013
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
====1st Method====
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account “Administrator” and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it’ll show Classic Login box. Now type “Administrator” (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from “Control Panel -> User Accounts”.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
====2nd Method====
1. Reboot your machine.
2. Press F8 before the Windows boot screen appears.
o Do not press F5 as used on the NT/9x series of Windows.
3. You will be be prompted with a boot options menu.
4. Select the Start Windows in Safe Mode option.
5. Click through several self-explanatory screens until your reach the familiar 'Welcome' screen.
6. Note that this welcome screen is limited to 256 colors and 640x480 resolution because the primary graphics will have been set to the Windows Safe Mode software VGA adapter. You will not be able to change this mode even in Display options, while Windows is running in Safe Mode.
7. Find the icon for the Administrator user. If the default settings of your system haven't been changed, there should be no password for this account.
o The Safe Mode Welcome screen might display some of the other users on your system.
8. Login as the admin.
9. Press Yes at the prompt asking if you would like to continue using Safe Mode.
10. Continue on to the User Settings control panel. Here you can change any of the other passwords for user on the machine. Make any changes you want.
11. Reboot your computer. As long as you don't press any keys (i.e. F8) during the boot-up the computer will startup normally.
12. Login as the user for which you set the password.
====3rd Method====
Windows XP and further versions also provide another method to recover forgotten password by using “Reset Disk”. If you created a Password Reset Disk in past, you can use that disk to reset the password. To know more about it, please visit following links:
http://support.microsoft.com/kb/305478
====4th method====
Comparatively, using windows password Recovery Tool utility is a reliable and convenient method for solving the password problem. Normally, the program can easily reset the password to “Blank” with no -reformatting or installation. Do all the job for you automatically. Unfortunately, it is not safe to use some free recovery tool to recover windows password. So here is the recommend recovery tool:windows password Recovery Tool 3.0 .
Offical site: http://www.windowspasswordsrecovery.com
you could see the recommendation of articlesbase.
http://www.articlesbase.com/security-articles/how-to-reset-recoverfind-forgotten-windows-nt-2000-xp-2003vista-administrator-password-1282019.html
====5th method====
If it doesn't work above ,I hope that you have some hacker friends.
====Reference resource====:
http://windowspassword.blog.com/
http://www.wikihow.com/Recover-Windows-Administrator-Password-if-You-Forgot-It
http://www.articlesbase.com/security-articles/how-to-reset-recoverfind-forgotten-windows-nt-2000-xp-2003vista-administrator-password-1282019.html#
http://www.instructables.com/id/How-to-Reset-Recover-Forgotten-Windows-NT-2000-2001/
Toshiba... | Answered on Nov 26, 2013
Toshiba Satellite A60 Notebook Logo
504 questions posted
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
toshiba satellite a60 password help
  • Computers & Internet
