20 Most Recent Toshiba Satellite A100-S8111TD Notebook Questions & Answers
Are you using the installation disk that came with your printer?
If yes, then you uninstall everything you installed and download an updated version of the software from HP Support pages. and use that instead.
Please report back and rate help! Good Luck
Toshiba... | Answered on Dec 15, 2018
we answered this a zillion time,s
google finds it 1st hit..
the real deal, not spam or worse endless scalpers on fixha
https://support.toshiba.com/support/products?cat=Computers
Toshiba... | Answered on Nov 29, 2018
Physically examine the make and model of the sound card as sometimes these are replaced with generic ones.
Alternatively, run a driver detector to get an accurate model of the sound card.
Toshiba... | Answered on Jan 02, 2018
Try using MHDD v4.6. It included in Hiren's Boot CD. You may have to write a script though, if you can figure out how.
Toshiba... | Answered on Apr 19, 2017
You can enable hibernation in Windows XP by following the steps below.
1. Type powercfg.cpl in the Run window. To get the Run window press Win key + R. Or, you can go to the control panel and click on Power Options.
2. Find the Hibernate tab and click on it. Check the Enable Hibernation check box. In case its necessary, free up some space on you C: drive by running disk cleanup or your favorite system cleanup utility.
3. Now you can hibernate your system by clicking on the Start button and then on the Turn Off Computer (or Turn Off ). You'll see three standard options, Standby, Turn Off And Restart.
Hold Shift key and you'll see the Standby button turns into Hibernate button. Click to hibernate (Still holding the Shift key).
4. Optionally you can do this: Create a batch file for hibernating, and put it on you desktop. Every time you need to hibernate your system, just double click this file from your desktop. To do this, First Open up Notepad, type the following line in it.
%windir%\system32\rundll32.exe powrprof.dll,SetSuspendState Hibernate
Then save the file as, something.bat onto your desktop. Run this batch file to hib
Or you can
manually put your computer into hibernation:
1)Open Power Options in Control Panel.
2)Click the Hibernate tab, and then select the Enable hibernate support check box.
If the Hibernate tab is not available, your computer does not support this feature.
3)Click OK to close the Power Options dialog box.
4)Click Start, and then click Shut Down. In the What do you want the computer to do drop-down list, click Hibernate.
To automatically put your computer into hibernation:
2)Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply.
If the Hibernate tab is unavailable, your computer does not support this feature.
3)Click the APM tab, click Enable Advanced Power Management support, and then click Apply.
4)Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Thanks
Toshiba... | Answered on May 24, 2016
Hey,
Toshiba A100 drivers are available at this webpage
http://eu.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/download_drivers_bios.jsp
Thanks,
Ekse
Toshiba... | Answered on Mar 24, 2016
above the start icon which is the window icon on the bottom left is a menu and on that menu is device manager, click device manager and it shows list of devices, on the list is network adapters. Open that branch by clicking on the > You should see the network adapter. If there are any ! or X or it is marked as unknown then you have driver issue. You can use another computer to download the driver and install it.
Toshiba... | Answered on Nov 27, 2015
First thing is the operating system. What windows version you ae using has a lot to do with how to proceed. You need to look in device manager in the control panel to see what it says about your wireless device. Then you should check the error messages to see what they are
Try a USB keyboard as a workround. This will allow you to try and re-install the keyboard drivers.
Toshiba... | Answered on Nov 03, 2015
It has stereo speakers built in but no microphone. It has a micrphone port though (it is purple or pink in color) where you can connect an external microphone.
Toshiba... | Answered on Sep 17, 2015
you need a virus scanner on the PC You usually goto start> Programs> and then look for the installed program - as mentioned below - run it and there you will an option to scan
Not sure what you may already have, PCs are often supplied with a commercial product such as Norton, Mcaffee or Kaspersky Usually the virus definitons get updated for the first 90days and then you have to purchase the product updates for an annual fee
Check to see what program you have - if is out ofdate, you will need to
  1. update and subscribe to the program or
  2. remove the program and install one of the free versions avaibable
There is also a good online virus scanner Heres is a link to one of the online scanners http://housecall.trendmicro.com/uk/
If you want to use one of the free programs - I suggest avast, I use that on all friends and family machines - but there are others
  1. Avast -- http://www.avast.com/en-gb/free-antivirus-download - to download the file -- Feee Registration for an annual key -- http://www.avast.com/en-gb/registration-free-antivirus.php
  2. AntiVir http://www.free-av.com/
  3. http://www.filehippo.com/download_antivir/
  4. AVG http://free.avg.com/gb-en/homepage
Two other programs to have
  1. Malwarebytes http://www.malwarebytes.org/mbam.php and
  2. superantispyware http://www.superantispyware.com/download.html
Do NOT have two antivirus programs installed and running onthe PC at the same time To remove the antivirus installed demo installed on the PC - you may need to use one of the removal tools
  • Norton Removal Toolhttp://service1.symantec.com/Support/tsgeninfo.nsf/docid/2005033108162039
  • Kaspersky Removal Tool A link to Kaspersky - this varies with different versions
  • http://support.kaspersky.com/faq/?qid=208279463
  • http://support.kaspersky.com/faq/?qid=193239279
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Toshiba... | Answered on Jul 20, 2015
one thing you can do is to disconnect the CMOS battery for about a minute or so to let the charge drain away, then re-connect it ( you could always renew it at the same time as they don't last forever ) This will reset the BIOS to default settings and a password will no longer be required. Good luck !
Toshiba... | Answered on Jun 29, 2015
Hi malki_100,
here you will find the drivers (just click on the download tab after having followed the link):
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1209157&rpn=PSAA0U&modelFilter=A100-S8111TD&selCategory=3&selFamily=1073768663&selModel=1209157|PSAA0U
Kind regards and thanks for using Fixya,
noris017
Toshiba... | Answered on Jun 23, 2015
This question doesn't make any sense.
Toshiba... | Answered on Jun 16, 2015
Go to this link provided below. There are many way that you might be able to retrieve your files.
http://www.tech-pro.net/how-to-recover-deleted-files.html
Good luck & kind regards.
Toshiba... | Answered on Apr 23, 2015
check power lead,check battery,,have you tryed starting with out the battery in,some will start with out the battery.
let me know how you get on,or send me more info.
Toshiba... | Answered on Apr 12, 2015
Toshiba Satellite A100-S8111TD Notebook Logo
1,769 questions posted
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
get free set up ms office 2003
  • Computers & Internet
