20 Most Recent LG 37LP1D 37 in. LCD Television Questions & Answers
It all depends on the DISH system and the TV. For the most part the CC signal is carried on the cable from the box to the TV. Not sure how you have the DISH connected to the TV, but lets assume its HDMI. Connected this way you should be able to go into the TV settings (use the remote that came with the TV, NOT the dish remote) and go into the settings or menu. From there look for audio. In the audio menu is a section for CC. You should be able to turn it on from there. Or just check on the LG remote. They sometimes have a CC button that you simply push to turn it on. Hope this helps
LG 37LP1D 37 in.... | Answered on Sep 19, 2019
Now,what happening to the tv power LED light indicaton,when u turn on the tv now?Tv don't have any power LED light incation at all or power LED light indication is flashing?Check ur power source with other devices,see if the outlet is the problems,if tv still have no power to the tv all.Tv LED power light indication is flashing?Tries tv unplug,replug it back like about an hour later for the tv to do a resetting itself back to the factory setting.Now tv should work be again.Still have the same problems,this indication ur tv have a bad or a dead power supply board.That the board,where the tv power a/c cord plug into it.If u understanding basic electronic and have all the tools.Take the tv backcover aparts.Check the tv power supply board carefully for dying capacitors parts,these capacitors parts are dying or dead,most of the times they're bulging up or puffing up onto it tops.Replaces these capacitors parts with new capacitors parts with the same micro ferid but higer voltages like about 5 or 10 voltages higher for better heat resistances and last longer.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
LG 37LP1D 37 in.... | Answered on Jan 11, 2019
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
LG 37LP1D 37 in.... | Answered on Apr 24, 2017
redrover 11-13-2007, 01:03 PM Well I stumbled onto the solution to my problem, finally, but no thanks to any of the tech at my cable
LG 37LP1D 37 in.... | Answered on Jan 07, 2017
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
LG 37LP1D 37 in.... | Answered on Mar 15, 2014
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
LG 37LP1D 37 in.... | Answered on Mar 01, 2014
Probably the internal power supply has failed.
LG 37LP1D 37 in.... | Answered on Oct 24, 2013
Check power outlet. Change it to another and try. Change input device to something that works. Look for any jammed buttons on the remote. Switch off TV manually, switch off power outlet, remove plug and cool it off for 48 hours and retry. If it does not work even then, this may need attention by a qualified service technician.
LG 37LP1D 37 in.... | Answered on Jul 28, 2012
LG 37LP1D 37 in. LCD Television Logo
Popular Tags
92 questions posted
Ekse
RONALD CARTER JR
View Most Popular
  • LG Televison & Video
Most Popular Question
lg lcd tv model 42lb5d closed caption
  • Televison & Video
