20 Most Recent Konica Minolta bizhub 350 All-In-One Laser Printer Questions & Answers
A new belt will have to be installed at which time the fuse in the new belt will be blown to start a new count from 0. Now you can replace the fuse in the old one if you know how.
Konica Minolta... | Answered on Feb 24, 2019
got the same problem. You can solve it by pressing Settings/Counter ==
Konica Minolta... | Answered on Feb 16, 2019
no such code for a bizhub 350
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Sep 28, 2018
Clean the registration sensor under the transfer belt or have them replaced also might need to replace the transfer belt
Konica Minolta... | Answered on Apr 07, 2018
is this a scan to email issue. normally is port 25 depending on the system being used
Konica Minolta... | Answered on Mar 25, 2018
sure its the right code could not find in the service manual for bizhub 350
restart the machine.
If error code appears call your tech services rep.
Konica Minolta... | Answered on Mar 19, 2018
in the userscreen
Konica Minolta... | Answered on Mar 18, 2018
why do you want to reset
Konica Minolta... | Answered on Mar 14, 2018
sir/mam
Fuser is low temp. reset in service mode, if code comes back do not reset as this deals with fuser the hot part can catch on fire
Konica Minolta... | Answered on Mar 11, 2018
are these third party?????? if so get OEM cartridge the chip may be bad, mite try cleaning chip contacts with ispololy alcchol
Konica Minolta... | Answered on Mar 10, 2018
what is the model number and any additional info
no such code for a bizhub 350 what is the model number
  1. Remove the toner cartridge.
  2. Get a paper towel or cotton swab.
  3. Clean off the glassy part of the toner by turning the gear on the side by hand while wiping the drum surface clean and remove any black lines of toner you see from the cartridge.
Konica Minolta... | Answered on Feb 28, 2018
replace the drum and developer
Konica Minolta... | Answered on Feb 25, 2018
no such code for bh 350
Konica Minolta... | Answered on Feb 19, 2018
what model no code for the bh 350
The hard drive is not turned on. enter service mode ( utility, meter count, details, stop, 0, 0, stop, 0, 1 - this should be pressed in exact succession) then go to system 2 and look for a place where it asks you about all the installed perifferals. Turn the hard drive setting on.
Konica Minolta... | Answered on Nov 16, 2017
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
1,100 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
c 0001 code konica minolta bizhub c350
  • Office Equipment & Supplies
