20 Most Recent Konica Minolta Bizhub C 353, Bizhub Color,bizhub C 253,konica,bizhub C 450,c 550 Questions & Answers
what model number???
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Feb 19, 2018
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Konica Minolta... | Answered on May 14, 2017
may be
-paper already have a blue back ground or any color.
-from CIS (camera) or Main board.
you can check option named drop out color.
Konica Minolta... | Answered on Mar 19, 2016
I have minolta c450 show error c d370... how can I solve this problem... plz reply me with solution.
Konica Minolta... | Answered on May 16, 2015
Just how you did with this one.
Konica Minolta... | Answered on Dec 17, 2014
need details - what OS, is it hardwired via USB or connecting via network or wifi - could be port is blocked in your router's firewall, could be port is blocked in the PCs firewall, could be lots of things. Not sure what you mean by going online to clear documents - online where? is this a "cloud" printer? try shutting off printer for 20-30 sec then restart it - that may clear docs stuck in it's internal memory. going to need more details if you expect anyone to offer more detailed troubleshooting.
Konica Minolta... | Answered on Dec 10, 2014
when machine waqs working atonce power failure occurred and after that it showed error D370
Konica Minolta... | Answered on Oct 31, 2012
Hi
C-2a03 is a magenta toner cartridge eeprom access error. You can clean the connections between the toner cartridge and the machine if dirty. Try reinstalling the toner cartridge, if the cartridge is bad it should be replaced, if the cartridge is fine then the PWB-M should be replaced. Hope this helps...please post back for further assistance.
Daniel
Konica Minolta... | Answered Yesterday
C-2704 - Charging corona/K
Replace the Black Charging Unit.
The erase lamp (EL) is unconnected, was some recently working on the image unit? If so they for got to connect a small connector that provides power to the Erase lamp. OR the lamp is burned out, remove the image unit remove assy. above the drum do not touch the drum. pull up from both end at the rear should be to connectors are they connected? Erase lamp is on that assy. LEDS array along the axis.
Konica Minolta... | Answered on Jan 15, 2019
to what
Konica Minolta... | Answered on Jan 14, 2019
I don't understand.
When you change developer.You want clear in service mode.(Counter)
Konica Minolta... | Answered on Jan 13, 2019
Konica Minolta Bizhub C 353, Bizhub Color,bizhub C 253,konica,bizhub C 450,c 550 Logo
20 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
documents hung in que machine not
  • Office Equipment & Supplies
