20 Most Recent Maytag MSD2650HES Stainless Steel Side by Side Refrigerator Questions & Answers
this fix could be a simple leaking connection or hose
you have some options
call a technician and have the problem properly diagnosed and get a quote
if the quote is around 40% of the price of a new unit then consider a new unit as parts for your unit will be at the no longer available stage lf you really do not water dispensed from the door , disconnect the system and use a jug of water in the fridge or purchase a water/ drink cooler but that is an option to consider
Maytag... | Answered on Aug 08, 2016
Hi
Turn the freezer setting to a lower (not as cold) temperature, and then pour hot/warm water over the tube in the freezer that provides the water for the ice. Yes, the water in the tube may have become frozen.
To access the drain, remove the items and shelves in the freezer, then remove the lower rear panel... there are 2 screws holding it in place about 2 feet up from the bottom. When you have the panel out, you'll see the drain below the evaporator coil... take that back, you won't actually see the drain 'cause it's covered by ice, but it's there.
You can use a turkey baster to suction up water, and an aluminum pan to catch the run-off.
Use a hair dryer to melt this block of ice. Then remove that aluminum shield that's sitting there... this will expose the actual drain hole. What I do at this point is pour some very hot water (not much, about a cup) into the drain to help thaw the ice in the drain and use a small flat head screwdriver that's about 4" long to poke/scrape/dig in there and help it out.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Maytag... | Answered on Sep 13, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Maytag... | Answered on Jun 12, 2011
NO YOU JUST HAVE TO DO A SERVICE ON THE SYSTEM BY CLEANING THE CONDENSER ,EVAPORATOR COIL AND FILTERS.
YOU MAY HAVE TO AN EYE CHECK AND MANUAL CHECK
Maytag... | Answered on Oct 24, 2010
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The reasons the air is not moving is usually two reasons
  1. The fan or blower has failed.
  2. The coil is covered over with ice and blocks the air flow.
The first reason is pretty simple to fix, you simply replace the air circulator and things are good again.
The second reason can be more difficult.
1. The timing device that runs the defrost cycle of the refrigerator is defective.
2. The heater coil that melts the water is shorted or not working
Usually the first thing to check is the heater coil. If there is resistance through the coil then most likely it is still good.
The timing device can be an advanced defrost control board or a mechanical timing device.
If the heater coil checks out to be good then the problem should be the timer.
For most situations, unplugging the refrigerator and allowing it to defrost on it’s own will get you going temporarily, till parts can be shipped to you. That will melt the ice and give you a few days or a couple of weeks till it ices up to the point where it will not work again.
So you can see here, the problem can usually be traced to one of three things.
  2. The timer device
  3. The electric heater coil
By methodically checking these parts you can isolate your problem and fix it.
Good luck.
Maytag... | Answered on Jul 12, 2010
Start by checking the water supply going to the fridge using the technique of the Master:
  • Turn off the water at the saddle tap valve
  • Disconnect the water line in the back of the fridge. Place the disconnected end in a bucket and open the saddle tap valve.
  • Observe the flow rate–water should shoot out vigorously. If not, then the saddle tap valve is probably gunked up with sediment and you’ll need to replace it.
That should restore normal water pressure.
If the water supply flow rate test, described above, appears normal, then the water inlet valve on the refrigerator may be gunked up with sediment. Here’s how we check for that:
  • Reconnect the water supply line to the valve and turn the water back on.
  • Disconnect the nylon tube from the dispenser side of the valve and replace it with section of tubing so you can out the other end in a bucket.
  • Now actuate the water dispenser and observe the flow out of the tube. It should be the same as the flow you observed in the first flow test described above. If not, then you know the valve is restricting the flow replace the valve.
Take care.
Maytag... | Answered on Jul 04, 2010
That is probably the compressor. There should be a fan close by. When the compressor runs, does this fan turn? The fan must work properly for the entire refrigerator to cool adequately. The purpose of the fan is to pull cool room air over the coils and remove heat. If this heat is not transferred to the outside of the refrigerator, the cooling cycle will not function properly.
If the fan is not turning, it will need to be replaced. These are readily available.
Maytag... | Answered on Oct 29, 2009
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Maytag... | Answered on Jul 06, 2008
Slide the frig out, (Unplug Frig. first) remove the cover so you can see the condenser, beside the condenser there is a switch that has to be carefully removed w/(fasteners) Take to your nearest appliance store, last time I did this it was like $52.00. Carefully plug-in, take not were the wiring goes usually they only fit just one way. reassemble cover, plug-in you should hear it kick on, good luck.
Maytag... | Answered on Oct 01, 2019
If you go to https://www.filtersfast.com/Maytag-Refrigerator-Water-Filters-cat.asp
It will show you styles of Maytag Refrigerators. If you click on the one that matches your style, it will show you possible areas the filter is located. You can then look in those areas. Once you locate it, then you can then identify your filter part # and replace if needed. You can also go to Maytags website and look up your model and find the manual. The manual will likely tell you where the filter is and what the part number is.
Maytag... | Answered on Sep 17, 2019
Is icemaker switched on. Usually located near icemaker/ Or maybe faulty switch
PLEASE CHECK THE CONNECTION CAREFULLY AND THEREAFTER IF NOT WORK THEN CONTACT TO WELL MACHANIC.
Maytag... | Answered on Sep 15, 2019
There may be a drip tray under the fridge, it needs to be checked and position properly
Maytag... | Answered on Aug 22, 2019
Sometimes the new board will be in defrost mode when you install it, leave it powered up for 30 minutes to see if it begins cooling... Maytag Refrigerator Control Board W10890094
Also be sure the code is entered properly, these will do NOTHING without the right code.
Maytag... | Answered on Aug 07, 2019
Maytag MSD2650HES Stainless Steel Side by Side Refrigerator Logo
12 questions posted
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Refrigerators
Most Popular Question
maytag msd2651hes fridge not cooling
  • Refrigerators
