20 Most Recent Sunpentown WC-30U Under-Counter Wine & Beverage Cooler 32-bottles NEW Questions & Answers
Here is a link to the manual. I hope it helps, because it says nothing about putting on handle. Maybe pics will help.
http://site.sunpentown.com/wc-30U_manual.pdf
Sunpentown... | Answered on Jan 28, 2015
You should refer to the user manual to help you troubleshoot your equipment located Here: http://www.manualslib.com/manual/574948/Sunpentown-Wc-30u.html
I hope this helps!
Good Luck!
Rich Lilja
Sunpentown... | Answered on Jul 22, 2014
Try disconnecting the battery for about ten minutes and reattaching positive cable and see if that resets it.
Electrical... | Answered 4 hours ago
Your governor is adjusted for the correct 60 hertz cycles. You may have lost residual voltage to excite the generator to produce ac. Being that it was sitting long time.
I could explain in lengthy conversations but you could just google : how to excite a generator and there is good write ups online as well if not better than what I could explain in detail.
Electrical... | Answered Yesterday
Make and Model where this brush and magnet resides?
Click COMMENT under my post.
There maybe a centrifugal switch that is stuck on the end cover of the Gen I think. Hope this helps.
Then most likely GenSet breaker trip is due to a ground fault. Isolate the fault as follows.
Open all breakers in the Winnie. Start generator without the power cable from the Winnie connected. Connect power cable from Winnie and wait a few seconds. If no trip, turn on main (disconnect) breaker in Winnie. Wait a few seconds, if no trip then proceed to turn on each circuit one at a time.
Comment here with results.
Champion RCJ8 (840) Copper Plus Small Engine Spark Plug, you can look online for socket size, usually 5/8 inch older ones are13/16
Electrical... | Answered 2 days ago
Browser search the term "drill fix generator" and follow instructions on how to use a regular electric drill to correct residual magnetism of a generator.
Electrical... | Answered 3 days ago
That model number is actually supported by Briggs & Stratton. The phone number to contact them for support is 1-800-274-4477.
Since you indicate that two remotes do not work, I am guessing the receiver on the opener is the problem. Verify that connections to the terminals (located where the wires from your hardline buttons are connected) are intact.
Electrical... | Answered on Apr 18, 2019
make and model?
Electrical... | Answered on Apr 16, 2019
well isnt that informative
Electrical... | Answered on Apr 12, 2019
Sunpentown WC-30U Under-Counter Wine & Beverage Cooler 32-bottles NEW Logo
4 questions posted
Top Sunpentown Electrical Supplies Experts
John Trevino
Richard Lilja
Richard Lilja
wadingriver
wadingriver
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sunpentown Electrical Supplies
Most Popular Question
put handle
  • Electrical Supplies
