20 Most Recent Konica Minolta Laser, Toner, BizHub Pro c5501, c6501 - Cyan - 25,000 Page YieldCyan - 25,000 Page Yield Questions & Answers
replace the black developer and or the black developer and black developer unit
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 10, 2018
whats the model number
cyan (blue) developer unit and or developer motor
Konica Minolta... | Answered on Mar 08, 2018
Please the copier model exactly.
Konica Minolta... | Answered on Oct 02, 2019
By contacting your local Konica Minolta servicer and reporting error 17
Konica Minolta... | Answered on Oct 01, 2019
There is another cover at the down right side of machine.Below the side door.Open it and then close it.Then bring out the tray and close it.Machine will start working.if not then tell me...
Konica Minolta... | Answered on Sep 04, 2019
You try cleaning and/or replacing the color registration assy?..
check the HV (high voltage board)..HV1 and HV2..
Konica Minolta... | Answered on Sep 01, 2019
Push down Stop buttom and switch on.
Konica Minolta... | Answered on Aug 19, 2019
The amount of toner in the developer is too high.
service mode.
adjust
tcr
+10
1.The terminal for the first transfer pressure/release sensor is not connected properly.
Reconnect the terminal.
2.Failed PS15 (p/n 08AA 8551 2).
Test photosensor, PS15, in the I/O State Confirmation Mode, 48-0HIGH = home position or LOW = Other than home position by activating M19 (p/n 08AA
8003 0) transfer pressure/release motor, 48-0, 48-1, 48-2, or 48-3. Replace thephotosensor or motor as needed.
3. Possiblefailed Transfer/Pressure Release motor (M19).
Check the operation of the motor(p/n 08AA 8003 0) in the I/O State confirmation mode for proper operation with code 48-0; this should rotate the motor
constantly. Replace motorif needed.
Also check for possibleopen ICP fuses, ICP3 (5V DC)and ICP4 (24V DC) on the AC drive board (p/n A03U H520 01). Replace the drive board as necessary.
SPECIAL NOTE : Solution contribution by KMBT (Japan) and Freddie Burnham, Production Print/SSD
C0200 - Cyan PC Drum Charge Corona Malfunction. Did you mess with this imaging unit? You won't be able to reset if the malfunction is still present.
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta... | Answered on Aug 17, 2019
Guess what! If you place a telephone call to a Konica Minolta service agent and mention 190f you may solve the mystery.
Konica Minolta... | Answered on Jul 29, 2019
Konica Minolta Laser, Toner, BizHub Pro c5501, c6501 - Cyan - 25,000 Page YieldCyan - 25,000 Page Yield Logo
4 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
bizhub pro c6501 c 2453 error code
  • Office Equipment & Supplies
