20 Most Recent Konica Minolta Bizhub C552 Copier Questions & Answers
Replace the IH Power supply, it will solve your problem... Page 71 Item 5 from the parts manual.
Konica Minolta... | Answered on Sep 09, 2018
Because there is a problem with tray four so it makes it disappear First open tray four remove the paper that might be stuck behind it.. Then enter service mode utility/counter, touch details on the meter count, then stop 00 stop 01 then select system 1, then select problem unit isolation, then select tray 4 your going to unset follow the screen, then your going to do the same process again this time set, if the draw continues to not show after this procedure get a tech out to look at it, as for tray three maybe the rollers need replacing have the tech look at them to.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Jan 10, 2016
Located under the control panel. Right side front cover. looks like a power supply. connects to the fuser,
Konica Minolta... | Answered on Dec 29, 2015
The IH power supply is located below the operational panel behind the front cover below the op panel,
Konica Minolta... | Answered on Nov 22, 2015
Have you changed the fusing unit? If try that first, then relace the IH Power supply or the (coil unit) is what the fuser attaches to when you install one. power supply is located right side under the control panel, .
Konica Minolta... | Answered on Nov 14, 2015
behind the right side cover under the control panel
Hey jrf, the manual says to check, in this order; proper fuser installation, proper closure ( door latch ) of the right hand door, check around-all around-for wiring connection issues, change fuser, then coil, then IHPU, then PRCB, then REDB. If you have a trade-in, or lease return, at the shop; it might pay to do some parts borrowing.
Konica Minolta... | Answered on Sep 23, 2015
Black drum ATDC replace the black developer unit, also check to make sure the black toner is getting into the black developer unit. Open close the front door to reset the code (Not the Toner door)
Konica Minolta... | Answered on Jun 14, 2015
again please explain?
Konica Minolta... | Answered on May 25, 2015
Hi
C-2a03 is a magenta toner cartridge eeprom access error. You can clean the connections between the toner cartridge and the machine if dirty. Try reinstalling the toner cartridge, if the cartridge is bad it should be replaced, if the cartridge is fine then the PWB-M should be replaced. Hope this helps...please post back for further assistance.
Daniel
Konica Minolta... | Answered Yesterday
C-2704 - Charging corona/K
Replace the Black Charging Unit.
The erase lamp (EL) is unconnected, was some recently working on the image unit? If so they for got to connect a small connector that provides power to the Erase lamp. OR the lamp is burned out, remove the image unit remove assy. above the drum do not touch the drum. pull up from both end at the rear should be to connectors are they connected? Erase lamp is on that assy. LEDS array along the axis.
Konica Minolta... | Answered on Jan 15, 2019
to what
Konica Minolta... | Answered on Jan 14, 2019
I don't understand.
When you change developer.You want clear in service mode.(Counter)
Konica Minolta... | Answered on Jan 13, 2019
need a developer or turn off press stoop button and turn on :) (it's a truble reset )
Konica Minolta... | Answered on Jan 11, 2019
Konica Minolta Bizhub C552 Copier Logo
14 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
George Mclaughlin
Clive
Clive
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
konica minolta c552 error c3b02
  • Office Equipment & Supplies
