20 Most Recent Zeiss Humphrey Acuitus 5015 Autorefractor Keratometer Tested Calibrated Cornea Questions & Answers
These equipments use a sbc492 by Aaeon motherboard, and usually they shows a message like "Cmos battery Low".These motherboards use an RTC M48T86PCI with a internal lithyum battery, and just replace that component.Other problems may occur, like damaged slots, and or oxidation, but generally the 486 architecture is a huge way to work,Only clean change the memory(dimm 128 x 100mh)and enjoy.A simple way is a replacement with a new one by Intel, still easy to find in some inventorys, i have many in USA who can suply.
hope to solved
Zeiss Humphrey... | Answered on Nov 13, 2018
i have the manual and the belt, pls contact at memoinstal@bol.com.br
marcelo
Zeiss Humphrey... | Answered on Jun 20, 2018
The problem is in the mainboard, look for j conectors, and try to see if any is released.They control the step motor who can make the camera focus
I need the same. I found in Ebay
Zeiss Humphrey... | Answered on Apr 14, 2016
Hi Mariela where you from, maybe i can help you.
Zeiss Humphrey... | Answered on Jul 31, 2015
Hola farfan! Sabes que tengo el mismo problema ! Nose si ya solucionaste eso, si supiste como, podrias decirme.
Zeiss Humphrey... | Answered on Apr 17, 2015
comunicate conmigo un this Correo luismartinezdsa@gmail.com
Zeiss Humphrey... | Answered on Mar 27, 2015
Hi Patricia where you from??Maybe i can help you.
marcelo
Zeiss Humphrey... | Answered on Oct 24, 2014
The batery is a integrated circuit that is soldered to the Mother Board. You should disolder that circuit in order to replace it
Zeiss Humphrey... | Answered on Sep 09, 2014
The battery can be seen circled in green in the photo below. It typically has a 10 year life. All apologies for the repeat text/ newbie here.d3d64cf2-75ae-495a-bf4e-dbcf5ee471c9.jpg
Zeiss Humphrey... | Answered on Aug 22, 2014
This is a brand name, not a specific device and model. That said, here is a page describing mode switch in the setup screen using the touch screen for a specific device. I assume a touch screen would have an icon for turning a device off.
Zeiss HUMPHREY 720i User Manual System Setup
Zeiss Science &... | Answered on Jun 16, 2018
The battery is soldered to the CPU. People from Zeiss Germany said that it needs to replace all the CPU. Now a days there is no longer spare parts for that instrument. I recommen you just change the day and time each time you turn it on
Zeiss Science &... | Answered on Jan 05, 2017
Zeiss Humphrey Acuitus 5015 Autorefractor Keratometer Tested Calibrated Cornea Logo
Popular Tags
19 questions posted
Top Zeiss Science & Laboratory Experts
Gep Pep
 Brian Main
Brian Main
Terry
Terry
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Zeiss Science & Laboratory
Most Popular Question
repair trying fix some motherboards
  • Science & Laboratory
