20 Most Recent Cyberhome CH-DVD 300 DVD Player Questions & Answers
my dvd player only plays movies back in black and white...not color. why?
Cyberhome CH-DVD... | Answered on Aug 24, 2019
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Cyberhome CH-DVD... | Answered on Jun 04, 2019
Hello
Get into this link, by copy and paste the link into the address bar of your browser. You can download the manual for your remote control from here.
www.ask.com/questions-about/Radio-Shack-3-in-One-Remote-Codes
Cyberhome CH-DVD... | Answered on May 19, 2018
Try using code search to find something that works. All universal remote controls do not contain all possible codes.
Cyberhome CH-DVD... | Answered on Feb 18, 2018
Wat is the code to dvp4000dvd player
Cyberhome CH-DVD... | Answered on Jan 22, 2018
Here is the quick start guide
https://docs.sony.com/release//DVPSR500H_qs_EN_FR_ES.pdf
You seem to be using the Video & Audio connection. Start at the Player. Connect cables to YELLOW Video, RED Right Audio WHITE Left Audio Then go to TV and find the YELLOW input RED input and WHITE input. On some TV's they are separate, some combine them with the COMPONENT inputs (Component is 5 cables you will use 3 of them if you only have COMPONENT inputs)
Some TV's have an input button on the remote but no on screen selection. Try pressing the input repeatedly to access the other inputs. Lastly you will not get upscaling if you are using the 3 cable hook-up. To get upscaling use an HDMI cable to connect. Be sure to not have both types of cables plugged in at the same time HDMI by itself is best. If you reply with the modelof the sanyo TV I'll try to get you more info.
Cyberhome CH-DVD... | Answered on Jan 05, 2018
Assuming the player is fine, the 'Bad Disc' display message usually means either a disc which is an incompatible format (for example DVD-ROM) with this player; a disc which is a region that does not match that of the unit; or a defective/damaged disc. Check the discs prior to using them in this player and if they are burned discs, make sure they are a compatible standard format for playback.
This model is not region-free by default unless stated otherwise in the manual.
Cyberhome CH-DVD... | Answered on Feb 02, 2017
Insert the DVD into the tray and does not read
Cyberhome CH-DVD... | Answered on Jan 30, 2017
There are lens cleaner discs available for this purpose.
Cyberhome CH-DVD... | Answered on Jan 04, 2016
Your player has to be able to play divx formats. Not all players come with that option.
Cyberhome CH-DVD... | Answered on Jul 21, 2015
the answer is "No". Your player cannot play MP4 DVD discs.
Take care.
Cyberhome CH-DVD... | Answered on Mar 17, 2015
Hey, I just unplugged my Cyberhome DVD for about 5 minutes and replugged it in. It is working fine. Try it with yours and let me know..
Lcamp518@zoominternet.net
Cyberhome CH-DVD... | Answered on Mar 04, 2015
Marlin P Jones & Assoc. Inc.. has a 5V 2.2A /12V 1.5A cord power supply that will fit into the space where the original power supply was! Lists for $6.95 but online price was $2.95. Works great! Connect 12V supply to the yellow lead and the 5V to the red lead of the output connector, black is ground, common to both supplies. Use QC terminals to the power cord input terminals, remove the cable clamp and the power supply will nestle beautifully in the space without need for support. (Remove the old circuit board plastic (3) and rear brass standoffs and use the front brass standoff for the output cable shield ground connection. (Part No. is 15955-PS) I bought two because I have a 2nd Cyberhome CD-DVD 300 which hasn't crapped out yet.
Cyberhome CH-DVD... | Answered on Jan 01, 2015
Cyberhome CH-DVD 300 DVD Player Logo
865 questions posted
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Cyberhome Televison & Video
Most Popular Question
push play button dvd player not work
  • Televison & Video
