20 Most Recent JCPenney Gyropter RC Helicopter Questions & Answers
Look online for a manual. Searching "Propel Gyropter Manual" Should bring up at least a pdf manual.
Chaio!
JCPenney... | Answered on Nov 29, 2015
there might be hair or fur stuck in your parts check that out
JCPenney... | Answered on Jul 20, 2015
Hi make sure you are on correct channel. Usually there are A B C channels. Look on your heli and try each one :)
The drive gear is either not engaged no or has stripped teeth.
JCPenney... | Answered on Feb 01, 2015
Replacement parts can be found on amazon, take a look: Amazon com Gyropter RC parts. I hope this was helpful. cheers
JCPenney... | Answered on Dec 10, 2014
I charged my gyropter ,and the bottom propeller spins slowly and makes a noise.
JCPenney... | Answered on Mar 18, 2014
It is spinning around because one of the rotors is not spinning at full speed. This happens when you bump a spinning rotor against something. Determine which one it is by observation or logic (i.e, the one that turns clockwise will produce counterclockwise torque, which is to be balanced by the other rotor spinning counter clockwise. So the counter clockwise spinning rotor is slow) Tighten the screw that holds that rotor that is spinning more slowly. Use the screwdriver that came with the spare parts.
JCPenney... | Answered on Dec 29, 2013
Glue it back on.
JCPenney... | Answered on Dec 07, 2013
Sounds like the battery is not charged fully. Mine did that after I pulled it out of the box. Let it charge for a while longer.
Chaio!
The Jcpenney ones seem to have the most problem with this. Some of the gears might be out together wrong, see if Jcpenney will take it back.
Chaio!
try to play around with the trimmer.. i had the same problem but then guessed it was the trimmer and iwas right!
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
JCPenney... | Answered on Dec 05, 2013
JCPenney Gyropter RC Helicopter Logo
83 questions posted
Top JCPenney Toys Experts
Marvin
Marvin
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a JCPenney Toy Expert? Answer questions, earn points and help others
View Most Popular
JCPenney Toys
  • JCPenney Toys
Most Popular Question
helicopter not turning after fell down
  • Toys
