20 Most Recent LG RU-42PX10 42 in. HD-Ready Plasma Television Questions & Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
LG RU-42PX10 42... | Answered on Sep 09, 2016
Try opening up the unit and cleaning the contacts and bottom of the buttons with a q-tip and a bit of rubbing alcohol. Over time the oil from your fingers gets inside and creates a film between the contacts and the button so the circuit will not complete and your buttons stop working.
LG RU-42PX10 42... | Answered on Apr 14, 2016
Before diving into the TV, make a simple check.
Take a flash light and shine close up onto the TV while it is running, if you can see picture then that tells you the inverter board is bad. If your backlight comes on and you can't see any picture then your video board has failed. If neither your backlight or video work then your power supply isn't feeding the proper voltages to those boards.
Since you have sound it most likely isn't the power supply, although stranger things have happened. Check the power supply last in this case.
From these checks you can isolate your problem and then dive into the TV.
LG RU-42PX10 42... | Answered on Jul 08, 2015
I believe that you are experiencing an intermittent problem with what's called your florescent lamp ballast. The best thing is that it can be repaired/fix. There should be a LG repair shop in your area. Cheaper to bring it in than have a service tech come to your residence.
Should be between $200 to $300 for a repair.
Blessings,
A/V Media Guy
LG RU-42PX10 42... | Answered on Mar 17, 2015
http://www.tv-repair-solutions.info
LG RU-42PX10 42... | Answered on Sep 17, 2014
http://tv-repair-solutions.info/
Psu problem replace and you should be fine
LG RU-42PX10 42... | Answered on Aug 15, 2014
This problem isn't a capacitor issue .Its a Y-sus issue or a panel issue
you need advanced help to solve this .
If the screen goes black while you still hear the sound playing, then it is time to send in the technician for repairing.
LG RU-42PX10 42... | Answered on Jul 26, 2014
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
LG RU-42PX10 42... | Answered on May 01, 2014
This is a common problem on these sets. As the menu is fine, this is highly suggestive of an internal failure.you have a driver board failing if you would open the set and on the left side is the Y-sustain board there are two boards connected to the Y SUS board. The one on the top drives the top half of the picture and the one on the bottom drives the lower half of the picture open the ribbon cables make sure to clean it or Re solder if you see needed turn set on and test, sometimes cleaning this will fix problem sometimes re soldering will fix problem and last resort is, the board itself is bad.Unfortunately,you need to diagnose and inspect all the components before replacing any part.If you wish to repair it yourself, i could give you a link to buy the service manual and would upload a troubleshooting chart ( generic ) that would explain how you need to diagnose the fault when you open the TV.However, there is no quick fix. It has to be opened and tested and then diagnosed.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
LG RU-42PX10 42... | Answered on Apr 11, 2014
Main board should be troubleshoot. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
LG RU-42PX10 42... | Answered on Apr 02, 2014
You have to open the TV, and look for it at its main power supply regulator board. There is no fuse; outside it. Gopakumar Gopalan Google
LG RU-42PX10 42... | Answered on Feb 22, 2014
If you have sound, it is usually a bad Ysustain board, check for an open fuse on the big board on the left. If bad Zsustain board (right side) you usually can see a very faint picture
LG RU-42PX10 42... | Answered on Feb 18, 2014
LG RU-42PX10 42 in. HD-Ready Plasma Television Logo
233 questions posted
Steve Allison
Steve Allison
View Most Popular
  • LG Televison & Video
Most Popular Question
troubleshoot reset password lg smart tv
  • Televison & Video
