20 Most Recent Sony BDP-S1100 DVD/Blu-ray Player Questions & Answers
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Sony Televison &... | Answered 4 hours ago
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.]/
Sony Televison &... | Answered 11 hours ago
That sounds like a protection against overheating. Remove the case and vacuum any heatsinks or fans you might see. Also make sure it in in a well ventilated spot, with nothing on top of it, or another heat producing appliance under it.
The Service Manual is here
https://www.manualslib.com/manual/954224/Sony-Dvp-Ns50p.html?page=1#manual
Sony Televison &... | Answered 2 days ago
The 4 blinking lights is usually a indication of a power problem. You can try to reset it to factory defaults.
Step 1: Remove the power cord.
Step 2: Hold down the power button and Volume down button at the same time. Do this for at least 15 seconds before going to step 3, this will clear all electrical from the board.
Step 3: While still holding the 2 buttons down plug the cord back in. Then about 5 seconds later release.
If that doesn't work and it only stays on for a second or two then the monitor part its self has gone bad.
Sony Televison &... | Answered 3 days ago
first of all you go the dish connecter shop
Sony Televison &... | Answered on Mar 21, 2019
Sony remote control have no0 set-up codes to Sanyo TVs.
Sony Televison &... | Answered on Mar 20, 2019
Is the Sony remote programmable ... Does the Sony Remote produce compatible codes ...
Change the tv system from PAL to NTSC if you're in the states.
Sony Televison &... | Answered on Mar 17, 2019
This is a pretty old set (2006) and you can get a much better TV (brighter, higher resolution) now for less than it would cost you to have someone fix it. If you want to open it up yourself, look for something that is causing it to overheat - air vents blocked by dust or an inoperable fan. Short of that, look for the next e-waste collection.
Sony Televison &... | Answered on Mar 16, 2019
THERE IS NOT WAY I KNOW OF SORRY
Sony BDP-S1100 DVD/Blu-ray Player Logo
2 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
assalamu alaikum sir sony fly back want
  • Televison & Video
