20 Most Recent Mitsubishi WD-52525 52" Rear Projection HDTV Questions & Answers
remove the lamp and check to see if its ok, if ok replace lamp thermal sensor
Mitsubishi... | Answered on Oct 10, 2019
did u by any chance open the assembly of the tv and touched the pcb board... the circuits on this board r very delicate and u shud be very if u r handling tis....
wen u switch on ur tv r u able to listen to any sound or wat?
if yes reply back, i wil help u
Mitsubishi... | Answered on Jul 25, 2019
I have a blinking yellow light and tv won't turn on
Mitsubishi... | Answered on Jun 22, 2018
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Mitsubishi... | Answered on Jan 21, 2018
The contrast setting may be misadjusted.
Mitsubishi... | Answered on Sep 29, 2017
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mitsubishi... | Answered on Apr 15, 2017
Good Day;
You may have a lamp going bad,when was the last time you replaced it? Or the DMD or light engine, try lamp first. Good Luck, big IRISH.
Mitsubishi... | Answered on Aug 07, 2016
Even if you replace the capacitors already mentioned in this
thread, you may still suffer from the Green LED of Death. Here is how Bronson279 helped me resolve the
problem. But note that it involves
adding a switch to your tv set and requires a bit of soldering ability and the
willingness to void your warranty. BUT
you can save big $$$$ on sending the set out for repair.
Here is my solution-
After replacing several bad capacitors (you can get replacement capacitors
from Mouser electronics on line by the way.. be sure to order the same capacitance
values and same or higher voltage rating and be sure they are rated for 105
degrees C.) I still had the dreaded G.L.O.D. Note that the first time I plugged it in
after taking it apart the G.L.O.D was not there and it powered up
normally. But when I had to unplug the
set to fully re assemble it, it came back.
The issue is caused by both the FMT board (formatter) and
the DM (Digital Module) board’s microprocessors tying to establish
communications with each other. Somehow a race condition gets started with each
thinking that the other board needs to be reset and then starting the boot
process over again.
You need to interrupt this cycle with a switch. Buy a DPDT switch from radio shack (or Mouser
Elec…) and again take apart your electrical chassis (If you have it apart
replacing bad caps you might as well add the switch or you may end up having to
disassemble the whole thing again.) On
the FMT board along the top edge near the input connector side of the chassis
there is a four wire connector labeled “FC”.
It has two black wires and 1 orange and one Brown wire. Leave the black wires connected and cut the orange and brown ones about an
inch from the connector. Solder four 12
inch wires onto the ends (one on the source side brown, source side orange and
one on the connector side brown and connector side orange) use heat shrink tubing to cover the solder
connection points. (If you can’t get tubing, then electrical tape will do, but
make sure the joints can’t short out to each other or the electrical chassis.) Now take the brown and orange wires from the
connector side and solder those to the middle two terminals of the DPDT switch
(one on each side not both to both terminals) Then pick one side of the outside
terminals of the switch and solder the source side brown and orange wires to
the terminal across from the same color (brown across from brown and orange
across from orange) See the diagram below.
The idea is to connect the wires normally when the switch is closed and
break the connection when the switch is thrown the other way. Before soldering
the wires to the switch add a piece of heat shrink tubing to wire so that you
can cover the solder point up after it is assembled.
Now re-assemble the electrical chassis and route the switch/wires
outside the chassis (I snipped a hole along the edge of the top fan shield to
get the wires out.) and put it back in the TV.
You need to also get the switch to the outside of the TV somehow (I
drilled a ½ inch hole in the plastic cover to snake the switch through but you
can do it however you like)
Here is how to use it-
From a fresh plug in- throw the switch to the OPEN position (the wires
are not connected) plug in the TV, the green LED should stop blinking after 60
secs like it is supposed to. Once it stops, flip the switch the other way so
the wires are connecting. Hit the power
button. The TV should turn on- your done!
Yeah!
From a plugged in, hmmm my power must have gone out,
state. Assuming you have the GLOD, flip
the switch to the open position, hit the reset button on the front of the tv,
wait for the blinking to stop, flip the switch back closed and turn the TV on
normally… Again you are done…
Note that the first time you turn on the TV you may have to
flip the switch the other way (if the TV won’t turn on even without a blinking
LED) This means that the switch was open and you need to have it closed to get
it to work. If you tried turning on the
TV with the switch open, start over by following the reset button procedure
above.
Note this is much easier to do than it sounds. Also note that it helps if you have the
repair manual. Its titled V26 Repair
Manual –full This is nice to have
because it has a wiring interconnect diagram also which details all the
connector placements
Mitsubishi... | Answered on Apr 27, 2016
usually changing the aspect ratio will do it .
Mitsubishi... | Answered on Feb 05, 2016
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
1,606 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
WD Mitsubishi
  • WD Mitsubishi
Most Popular Question
bulb goes out after few minutes
  • Televison & Video
