20 Most Recent Timex 27191 Wristwatch Questions & Answers
The back pops off by using a pen knife or tool . With the sharp edge between the cap and watch cast use a quick pop motion and it will come off, be careful not to cut yourself
There are three batteries in the wr30 you will see two batteries when you open the back a large one and a small one. Underneath the large battery is the smaller battery so 3 different batteries
Timex 27191... | Answered on Aug 31, 2019
For the analog Timex Indiglo with both day and date (CR 2016 Cell on back) and only the single crown available you must first pull out the stem and turn through the hours 24 at a time to get to the correct day(MON,TUES,etc.). Then you can pull the stem out only half way and set the date (1,2,3,etc.). Be careful to attend to the AM/PM time as you turn the stem for the day. Go too far and the day will change at noon and you have to wind through seven more 24 hours to correct it.
Timex 27191... | Answered on Jul 06, 2019
For my sportech wr 30m it worked exactly like vrrr6 said, thanks!!
Timex 27191... | Answered on Feb 16, 2019
Yeah, I had this problem on a Timex Indiglo, but didn't have it on the cheap $20 watches in drug stores and discount stores. Timex puts a tighter cap on the back, probably for quality reasons, and you cannot push it together by your thumb. --This solution should work for about anyone: 1. Put the watch face down on a hard surface, but protect the crystal from scratching by putting a piece of cardboard or cloth between them. 2. Align the back and put a socket from a socket set on it that is somewhat smaller than the back cap. 3. Tap the socket with a hammer. You don't need to tap hard--even less than what would start a small nail. It may take only one tap--getting it aligned right is the key.
Timex 27191... | Answered on Nov 24, 2017
place the back plate in the freezer till its really cold itll snap right in there:)
Timex 27191... | Answered on Oct 17, 2017
I have the same problem. Did you guys find how to do it? Please let me know. M
Timex 27191... | Answered on Jul 20, 2015
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Timex 27191... | Answered on Apr 27, 2015
If the hairspring is perfectly clean (pretty clean is not good enough), then you have to observe it by using magnification eyeglass. Check out if the coiled parts are touching each other while the balance wheel is in motion. If that happens you need to recoil/repair hairspring and make coiling perfectly even. Also check out if the hairspring is touching balance wheel or coc;k. It must not touch anythining and must expand and retract freely. Coc;k is the bridge on which the hairspring stud and regulator (index) is fitted. When this is sorted but the problem still persists, get back to me again I'll guide you through the next stage of possible solutions.
Timex 27191... | Answered on Feb 09, 2015
I have a burberry watch and it has water droplets in it but its only the middle that's full of water dropplet
Timex 27191... | Answered on Jan 20, 2015
Timex 27191 Wristwatch Logo
342 questions posted
Top Timex Watches Experts
Janelle Schoonover
Janelle Schoonover
pacdave
 Mikey
Mikey
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
watch face water droplets inside
  • Watches
