20 Most Recent Toshiba Satellite L455S5980 Notebook Questions & Answers
Sounds like your CPU and HeatSink needs a fresh coat of Thermal Paste on them. You'd have to take the laptop apart to do it. It's shortening out because the paste is dry and causing metal to touch metal and shortening out.
Toshiba... | Answered on Mar 09, 2018
remove the hdd1/ssd1 user password from labtop toshiba
Toshiba... | Answered on Nov 14, 2014
If you pull the fridge out into the room, that will give you more movement. It will only need 6" or so.
Toshiba... | Answered on Apr 09, 2014
If you get prompted for the HDD password when turning on the computer, and you do not know it you will need to call Toshiba support. Circumventing an HDD password is not an easy task.
Also there where Toshiba laptops, model 6100, that when the user was suddenly prompted for the HDD password Toshiba replaced the HDD under warranty.
Toshiba... | Answered on Feb 11, 2014
You have a choice. Type in the correct password or replace the hard drive. There is no other option.
Toshiba... | Answered on Feb 06, 2014
JUST CALL TOSHIBA...
Toshiba... | Answered on Jan 06, 2014
I have bought a used toshiba satellite L555D-S7006 with windows 7 home premium 64 bit with the amd processor, it was working great. Well the other day I turned it on and it said to enter the bios password, I never put a bios password into the computer. I did some research on this and took the motherboard over to a freinds and he removed the cmos battery, after i reinstalled the motherboard now its asking for a HDD1/SSD1 password. So does anybody have any ideas about how to fixx this problem
Toshiba... | Answered on Nov 06, 2013
Ask your network administrator.
Toshiba... | Answered on Oct 19, 2013
You hit the correct jumpers for this model to remove the motherboard bios lock, which shows you have done your homework well. Toshiba, like Dell set a bios lock and HDD lock on some laptops for security reasons, often when the cmos battery needs changing, it manifests itself.
As to why you got this request for a bios pass is very odd, if you did not change the cmos battery, however, removing the battery as you state would not fix the hard drive problem. The hard drive will remain locked and if, as I suspect, it is a security measure, you will not be able to remove it and externally access files or even format it by slaving it in another computer or docking station.
Your best solution would be to contact a Toshiba service centre and explain the problem and ask them for a bios unlock code. IF this was installed at the factory, they should be able to remove it (you WILL be asked to provide proof of ownership)
I have heard of some laptops being "time locked", which is where the time/ date settings in the bios trigger a request for a bios password for security purposes, but never actually seen this occur. This might explain why the bios pass request appeared randomly as it did. There is the possibility that this was caused by a virus, although, again, I've never heard of this happening.
Toshiba... | Answered on Aug 11, 2013
I presume that this message comes up when you first turn the laptop on. In that case the Hard Drive has been lock with a password. The is no way to remove this with either knowing the password or sending the laptop to a specialist who can remove the password for you.
Toshiba... | Answered on Dec 05, 2012
Sorry I don't know/have your password.
Toshiba... | Answered on Nov 21, 2012
Lost Windows password:
  • Login as Administrator. Try with no password (load safe mode if you don't see Administrator). Press F8 during boot to access Safe Mode.
  • Login as other user (if other user is available) and manage users. Must be an administrator.
  • Reformat computer.
  • Use 3rd party software to remove password. Like http://www.top-password.com/reset-windows-password.html
Toshiba... | Answered on Oct 04, 2012
Make sure that the cable is good first off.
Download the printers driver from its manufacturers website support page
Windows 7 should automatically offer the printer driver as an update in Windows Update(Start Menu>Search Bar>Windows Update)
Toshiba... | Answered on Aug 01, 2012
Try this:;Click Start > Run > write services.msc > Right click on the running service that you want to stop.
If problem still occurs then use a sytem utility tool like Reginout for an instant fix.
Toshiba... | Answered on Apr 25, 2012
Toshiba Satellite L455S5980 Notebook Logo
Popular Tags
62 questions posted
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
please enter hdd1 ssd1 user password
  • Computers & Internet
