20 Most Recent Kenmore 44921 Front Load Washer Questions & Answers
you can run a regular cycle with bleach as instructed in the manual. there may be mold on the rubber where the door closes. wash this with water and bleach. to avoid this problem in the future you can loosen the light bulb then you can leave the door open a little all the time with no light. press the off button when not in use.
Kenmore 44921... | Answered on Jul 26, 2017
Hi, it sounds like you have a major problem with your washer. The inner steel basket has a shaft attached to the back of it that goes through the rear of the outer plastic tub and attaches to the drive pulley. More than likely the shaft has broken off, the basket alone is over $500.00. It will more than likely need the rear of the tub as well for the seal and bearing. I have seen this many times. I would recommend buying a new washer unless you have some sort of extended warranty.
Kenmore 44921... | Answered on Apr 17, 2014
Hi
To unlock them press and hold the DRAIN/SPIN button for 10 seconds. Hope this helps....
Daniel
Kenmore 44921... | Answered on Jan 19, 2011
Check on the drain valve /drain pump and test if the voltage comes to the component. If so the drain pump is not working well. You can remove and test on bench, clean and back flush to remove dirt and see for a good flow. Once confirmed refit or else the pump must be replaced if the pump is not performing as required , the coil can be faulty.
However if voltage is not present on the pump after the wash cycle and during the rinse cycle, the controller can be defective.
Kenmore 44921... | Answered on Aug 31, 2010
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Kenmore 44921... | Answered on Aug 01, 2010
Hi
Thanks for using FixYa. Error code F/H means no water was detected entering machine or Pressure switch trip not detected. If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed. It can also happen if the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash. You’ll need to Press PAUSE/CANCEL twice to clear the display and then check:
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and
Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump,
Flow Meter and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Kenmore 44921... | Answered on Jun 03, 2010
"F02" is a Long Drain error code. This is an indication of an obstruction somewhere in the drainage system. In most cases, the drain pump reservoir needs to be cleaned out. The following link explains how:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If you check the drain pump reservoir and the problem still persists, you may have a pump with a damaged motor/impeller, or something lodged in one of the drain lines. In particular, the drain line that runs from the bottom of the wash tub to the inlet side of the pump.
I recommend you remove the inlet hose, as well, and inspect for clogs. In is common for small garments to become lodged in this area and restrict water flow to the drain pump. Check the output drain line for obstructions as well.
It does not take much to damage this small drain pumps. The error code is generated if the drain cycle exceeds 8 minutes. So...if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may still experience the drain error. In this case, you will have to replace the pump in order to get the error to clear. The following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Kenmore 44921... | Answered on Mar 19, 2010
All front loader have this problem. Use concentrated lemon juice to clean the boot and then you will have to leave the door ajar just a bit every time you finish washing. Sorry but this the nature of having a front loader. Also using powdered soap products will also almost completly do away with this problem.
Kenmore 44921... | Answered on Jan 31, 2010
this is a drain problem.inspect the water pump, motor coupler and the drain hose for kinks.
Kenmore 44921... | Answered on Dec 14, 2008
if softner has discharged it's probably working ok some water left behind is normal
Kenmore 44921... | Answered on Jun 24, 2008
If this is a 417 model your problem might be the pump itself. There is a pressure switch that detects whether or not there is any water left in the tub. If so, it will not go into high spin. Remove the lower panel and check the pump on the lower right side. See if there is any gunk or coins in there by removing the hoses attached to it. Have a flat pan or a bunch of towells ready to catch the remaining water from the tub. If the pump checks ok, the next move would be to check the motor controller itself.
Kenmore 44921... | Answered on Apr 25, 2006
Could be motor coupler about to go or agitator dogs worn out. Both fairly simple fixes although coupler requires extensive machine disassembly
Kenmore Washing... | Answered Yesterday
https://www.searspartsdirect.com/washer-repair/error-codes/kenmore-110-model-vmax-top-load-washer-error-codes.html
Mismatch of the main electronic control board and the user interface control The code appears when you install the wrong user interface control. Order and install the correct user interface control for your model of washer.
Kenmore Washing... | Answered on Feb 15, 2019
Replace it or call service tech to do it.
Kenmore Washing... | Answered on Feb 14, 2019
Kenmore 44921 Front Load Washer Logo
22 questions posted
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
View Most Popular
  • Kenmore Washing Machines
Most Popular Question
water not completeing draining
  • Washing Machines
