20 Most Recent GE Profile PSW26P Stainless Steel Side by Side Refrigerator Questions & Answers
I had the same problem with the freezer sheles being too small in my GE Profile side by side. The shelves would simply collapse down with any weight on them.
After measurng the gap, I determined that the shelves were approximately 7/16" too narrow.
The fix I did was simple, effective, and very cheap.
I bought a roll of clear flexible polyethylene tubing at Lowes for about $5.The tubing is 3/8" outer diameter, 1/4" inner diameter (see picture below).
I cut pieces to fit along the side rails of the shelf, and then sliced the tube pieces down their length with a utility knife. I wrapped the pieces around the outside rails on each side of the shelf. It took a little work, but I got the tube pieces attached.
In a few spots, I did a double wrap of tubing.
The shelves fit tightly now and can hold significant weight without collapsing. Plus, they don't look too bad.
I hope GE fixes this simple problem in the future.
2_29_2012_2_35_52_am.jpg2_29_2012_2_36_07_am.jpg2_29_2012_2_36_33_am.jpg2_29_2012_2_36_53_am.jpg
GE Profile... | Answered on Aug 02, 2018
JSL Arc, is the best choice from where you can get the best quality stainless steel product like Stainless Steel Panels, stainless steel industrial kitchen products, coated steel sheet, portable stainless steel toilet, stainless steel railing, stainless steel staircase railing and many more. JSL Architecture Ltd provides all stainless steel products that you will need for your home: stainless steel balcony railings, stainless steel handrails to stainless steel staircase railing designs. For more details Visit at Stainless Steel Products
GE Profile... | Answered on May 11, 2018
It may be a hole in the water line leaking.
GE Profile... | Answered on Nov 09, 2017
Model # would be helpful, but most likely something going in with damper that controls airflow between freezer and fridge side. Also could be thermostat
GE Profile... | Answered on Nov 07, 2017
HELLO Anonymous,
I think you are having a basic PROBLEM with
the idea that FREE ADVICE could actually
be valuable...
You need to make up your mind...
If "NOTHING will FREEZE"...
Then how in the world could it
"seem to DEFROST" ...??
(bull-feathers)
What you are saying is contradictory nonsense...
I can totally ASSURE YOU an 80°F or 90°F degree
ambient temperature would have very little effect
on a WORKING REFRIGERATOR...
Think Fresno, Bakersfield or Mojave
(and get over it).
I come here daily... If YOU want to get serious
about your REFRIGERATION ISSUES...
I love refrigerators... and stop by DAILY...
Get serious about your symptoms...
Buy the applicable TAYLOR thermometer
and MONITOR precisely of WHAT YOU SPEAK...
Together.. We can do this...!!
Buy & use this ($6 refrigerator thermometer):
https://www.amazon.com/Taylor-Precision-Products-Thermometer-Refrigerator/dp/B000BPE88E/ref=sr_1_14?ie=UTF8&qid=1507620811&sr=8-14&keywords=taylor+thermometer
We can do this (if you wish)
Carnac the Magnificent
GE Profile... | Answered on Oct 10, 2017
Clean vacuum rear of fridge check to see if fan is spinning freely
GE Profile... | Answered on Oct 05, 2017
Sounds like the main control board is bad..would need model number to give more educated diag..
GE Profile... | Answered on Jul 12, 2017
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
GE Profile... | Answered on Jun 10, 2017
If the motor is running but it's not getting cold then you may have lost coolant. Did someone clean the ice out with a knife?
GE Profile... | Answered on Apr 28, 2017
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
GE Profile... | Answered on Apr 14, 2017
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
1,218 questions posted
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
View Most Popular
GE Refrigerators
  • GE Refrigerators
Most Popular Question
chill or freeze thermostate replaced
  • Refrigerators
