20 Most Recent Bosch WFLI 2440 Front Load Washer Questions & Answers
fault may be tacho on motor fallen off or round magnet that turns inside the tacho coil has become unscrewed. remove motor and check tacho. it is located at opposite end to the belt pulley
Bosch WFLI 2440... | Answered on Aug 25, 2014
Hello.
If your washer is indeed a WFL2066, than the not spinning is directly relatedto the unit not draining.
These machines by design cannot spin if the drain is inadequate.
Here is the first step in resolving the problem, you need to access the drainpump/filter to clean it.
To reach the filter and clean it...
**Unplug the washer from the dryer or wall, or turn off the 30amp breakerat the home service panel...safety first**
1) Open the small square plastic door at the right bottom of thewasher.
2) Via the small hose drain any access water from the pump...this is where awet/dry shop-vac comes in handy, or a shallow pan with a few towels works a swell.
3) Then turn the pump insert/button trap counter clock-wise and pull out.Clean the trap out thoroughly running it under hot water and mild soap or your washer detergent and inspect inside the pump for any other foreign objects/obstructions.
4) Re-install the lint trap insuring it is good and snug/tight. Before closing up the small access door, run a short rinse spin cycle to check frleaks.
Let me know how you make out, or if you require further assistance.
Thank you for visiting our site please take a moment to rate the info-provided for you here.
Thanks.
Bosch WFLI 2440... | Answered on Sep 30, 2011
'....water in drum won't drain'
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Bosch WFLI 2440... | Answered on Sep 10, 2011
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
John C
Bosch WFLI 2440... | Answered on Jun 20, 2011
yes u will need to do the both of them
Bosch WFLI 2440... | Answered on Dec 09, 2010
Remove the motor and check the brushes, if they are less than 3 or 4mm long, replace them.
Bosch WFLI 2440... | Answered on Oct 17, 2010
your soap drawer is most likely to be blocked , the only true way of clearing the blockage is to take the soap dispenser completely out . you will see that all the jets will be blocked ,you can do this before taking it all apart by taking the drawer out band looking up, if it looks clean ie; no black gunge then it may be a water valve problem, as the cold fill side has 2 internal valves both have come on together to clear the conditioner compartment.
Bosch WFLI 2440... | Answered on Jan 13, 2010
Remove the dispenser from the m/c, and thoroughly strip and clean every part. fill the conditioner compartment with water to the top, and the water should syphon away to leave it empty.
Get a piece of thin stiff wire , make a hook on the end, and poke it into all the holes you can see in the top of the conditioner compartment, this will unblock any that are clogged up.
Should solve your problem
Plz leave feedback.
Ta.
Bosch WFLI 2440... | Answered on Dec 09, 2008
filter is probably the problem. the round cap unscrews and then just pull filter out
Bosch WFLI 2440... | Answered on Sep 07, 2008
Vanessa Lopez Oct 12, 2019
I have a Bosch 300 Series on a pedestal. Pull the drawer out completely and reach to the back of the slides, you will feel the plastic release. The left one presses up (pull the drawer a little While you press the tab up), the right one presses down (pull the drawer a little while you press that tab down). Now you can simply pull the drawer all the way out.
Bosch Washing... | Answered Yesterday
I get paid over $180 per hour working from home with 2 kids at home. I just got ypaid $ 8550 in my previous month It Sounds unbelievable but you wont forgive ourself if you don't check it..... http://www.Geosalary.com
Bosch Washing... | Answered on Oct 06, 2019
Check that the load is within the 6kg limit and not entangled into a ball, which will unbalance the drum. Separate the items and try again. I believe Bosch has a telephone help line.
Bosch Washing... | Answered on Oct 01, 2019
Original advice in 2014 from Kenjo, on another website:
f21 is worn brushes in the motor replace them and to reset the f21 code.... close the door, turn timer dial to position 8 going clockwise, hold in the spin speed button whilst turning dial to position 9 let go of spin speed button and return dial to off position.
Bosch WFLI 2440 Front Load Washer Logo
23 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
wfli2440 front load fabric softener not
  • Washing Machines
