20 Most Recent KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Questions & Answers
We had the same problem. Our fridge was beeping and the lights would not come on. To stop the beeping and turn the lights back on we had to press the OVER TEMPERATURE RESET button. As soon as we did this, the lights came back on and beeping stopped. Hope this helps.
KitchenAid... | Answered on Aug 07, 2019
Our refridgerator has terrible tasting ice and water and we have tried everything to fix it. Is there a sure fire way to fix the problem. I would love to use the ice maker and water.
miracow
KitchenAid... | Answered on Jul 02, 2019
Put a in-line water filter on the water line if you want. The taste is from the food and items you have in the refrigerator. Clean it out and keep your items in proper storage. Ice collects the smells in the line and the fridge. Change your ice that is sitting in the bin, wask out the bin with water and baking soda. Hope this helps.
KitchenAid... | Answered on Sep 07, 2018
Hello ted, I see that you have replaced the compressor fan motor and you have assured as well that the fan is working correct? In all actuality it is best to put the outside fan source around the rear of the machine to blow directly on the compressor itself. Questions for you how fast is the new compressor fan motor spining does it look like it is working properly or is it spining slowly? If the fan were spining properly then you would look at an issue most likely with the condensor where you would most likely have a clog in the condensor itself. You would have to call for a technician to come to your house and replace the condensor. I will await your reply Thanks
Rick
p.s you could also have a clogged capilary line as well which would also cause this as well where the oil from the compressor is not able to move to cool so instead it just heats up due to a blockage in either the capilary, the condensor, or one of the lines. This usually happens from the compressor fan motor not cooling and the unit running and not being able to cool.
KitchenAid... | Answered on Jul 17, 2018
I hope I'm leading you in the right direction...
try this site...I found the part I believe and there is a install video there...
http://www.appliancepartspros.com/whirlpool-valve-solenoid-single-wp2313917-ap6007232.html
hope it helps.
KitchenAid... | Answered on Feb 27, 2018
If you get us a Model # it would help FIXYA Folks help with some suggestions.
Should be Inside the refrigerator, on the left wall. silver sticker. Thanks
At the ripe old age of 21, the entire appliance is a candidate for replacement.
KitchenAid... | Answered on Jan 25, 2018
In a few cases, the timer is getting condensation damage from a poorly sealing door, or a missing shield. Commonly you'll see corrosion or stains on the timer when you remove it which would be a tattletale sign. Check for both when it fails next.
KitchenAid... | Answered on Jan 09, 2018
if it is supposed to be a frost free, then either the defrost element has failed or the timer for same has . I would suggest you call a repair service tech.
KitchenAid... | Answered on Dec 28, 2017
Obviously there is an issue, perhaps a safety issue.
Suggest don't over-ride anything.
Check your owner's manual to see what blinking light indicates.
KitchenAid... | Answered on Nov 02, 2017
Sounds like a defrost problem if the evaporator is frozen over. If it's just Ice blocking air transfer on a top freezer model, then it's a blocked defrost drain.
KitchenAid... | Answered on Sep 11, 2017
OptimIce
Feature
The OptimIce feature assists with temporary periods of heavy
ice use by increasing ice production.
Press the OptimIce feature touch pad to set the freezer to
the lowest temperature setting. Press the OptimIce touch pad again to return to the normal freezer set point.
NOTE: The OptimIce feature will automatically shut off in
approximately 24 hours
KitchenAid... | Answered on Aug 28, 2017
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
1,409 questions posted
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Refrigerators
Most Popular Question
water dispenser liiks
  • Refrigerators
